他们逼我做卧底
XL6019 adjustable voltage module
XL6019 is a monolithic integrated circuit specially designed for voltage boost and buck-boost. It can work in the input voltage range from DC5V to 40V, has low ripple and built-in power MOS. XL6019 has built-in fixed frequency oscillator and frequency compensation circuit, which simplifies circuit design. The PWM control loop can adjust the duty cycle to vary linearly from 0 to 90%. Built-in over-current protection function and EN pin logic level shutdown function.
Vin: 5V-40V
Vout: Vin-40V
The VOUT voltage can be adjusted by modifying R1 and R2.
The corresponding capacitor withstand voltage also needs to be adjusted
as follows: VOUT=1.25*(1+R2/R1).
Higher precision adjustment is required and the potential can be replaced. device
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 17:31:36
