兰博
[Minimum system] STC32G12K128 core board V1.3
                                       To borrow a sentence from the STC official website: 2022, the first year of 32-bit 8051! The most important weapon of the country, the backbone of the country, all industrial regulations, strong anti-interference.
      Seeing this, the unique official website homepage has emerged in your mind. Yes, today we recommend a 2022 latest 32-bit 8051 core microcontroller: STC32G12K128 . In order to help everyone learn STC32 better, we specially designed this very exquisite core board with CH340 chip onboard. You can use it as soon as you get the development board. There is also an LED power light and a power-off reset button reserved on the board. , a user button, (multiple LED lights, you can choose and stick them on your own), and an external 24C02 memory, making your STC32 learning journey more convenient. Next, we will introduce some of the main features of the core board:
1. Chip characteristics
      STC32G series microcontroller is a 32-bit 8051 microcontroller targeting super anti-interference/ultra-low price/high speed/low power consumption. At the same operating frequency, the STC32G series microcontroller is The traditional 8051 microcontroller is about 70 times faster. It can be seen that the performance of STC's 32-bit microcontroller is not ordinary.
      The chip has a built-in high-precision R/C clock, which can be used without an external crystal oscillator. The main frequency is 33Mhz. The chip provides a wealth of digital peripherals, including 4 serial ports, 5 timers, 2 advanced PWM timers with dead zone control, IIC, SPI, USB, CAN, LIN interfaces and ultra-high-speed 12-bit ADC and comparison device to meet most design needs. What reasons do we have to reject this cost-effective 32-bit microcontroller launched by STC?
2 Onboard resource
main control chip: STC32G12K128, LQFP-48 patch package
Power supply connection: Use 1 Type C for power supply or connect to the computer for program download
Serial port download: Use the CH340N chip to communicate with the computer, no external downloader
LED display : One power indicator light and N status indicator
light button control: A power-off switch for chip cold start download, an independent button with interrupt function
Program expansion: Use the IIC interface to plug in an M24C20 EEPROM chip
pin header interface: isolate the chip Most of the pins are lead out and are compatible with other mainstream microcontroller core board pin arrangements.
Reference voltage source: Use the TL431 reference voltage source to provide a stable 2.5V reference voltage for the microcontroller.
      The onboard serial port download of this core board makes it easy to learn and debug. From learning the most basic input and output functions, serial communication, IIC communication, and important functions such as interrupts, timers, and PWM of the microcontroller, all can be done in this core Learn on the board. All pins of the core board are lead out and are compatible with other mainstream microcontrollers. The distance between the upper and lower pins of the board is 15.24mm (600mil). It can be inserted into a breadboard or perforated board to facilitate function expansion and debugging, and can quickly complete project verification. , making microcontroller learning easier.
3 Advantages and Features
: Compact appearance: The board size is only 53.34mm*30mm (2100mil*1181.110mil), and can be used with any base plate for project development.
High cost-effectiveness: 32% performance at a price of 51.
Flexible design: all functional pins IO are lead out for convenience Convenient verification and debugging of various functions
: onboard CH340N serial port chip, program download and debugging without downloader
4 application scenarios
circuit EDA software learning, learning circuit schematics and PCB design, learning to make a minimum system
college teaching application, learning Microcomputer principles and programming, use this core board to complete the course design project for
electronic enthusiasts to learn, master the microcontroller circuit design and program development capabilities, learn project development specifications for
electronic engineer verification, quickly get started with the study of STC32 microcontroller, and verify the required functions Development
competition learning and training can quickly build the required circuits in e-sports
4 Video tutorial
     4-1 Hardware teaching resources
      video teaching link: https://space.bilibili.com/494969171/channel/collectiondetail?sid=635687
     4- 2 Software teaching resource
     video teaching link: https://www.bilibili.com/video/BV1mK411Z7AT
5 Contact information
      If you encounter problems during the learning process, you can add WeChat communication: Alex2-one
            or join QQ communication group: 702805632
      to communicate and learn STC32 microcontroller together .
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 22:31:27
