toothache
[Shuangqiu awe-inspiring FRPS] Plug and unplug server power cage
It is said that technology is based on changing its shell
this time. . . .
Get some in the shell.
Design background: Traditional self-made server power supply backplanes usually have exposed pins and are prone to short-circuit when touching metal. At the same time, friends who have done this will know how tight the 64p interface is (only the world of desktop injuries has been achieved) with metal power supplies. The outer casing is prone to oxidation and rust, which makes it unsightly after being stored for a long time. Therefore
, we designed this [FRPS series] server power cage. As for technology, changing the outer casing can make us far ahead
. All.
This project is under the CC-BY-NC-SA license (i.e. Creative Commons-Attribution-Noncommercial-Share Alike) and unauthorized deductions (cutting out parts of the original project or modifying new ones based on the original project) are prohibited. The
project is called "deduction"). Even if it is authorized, the project must be shared in the same way before it can be deduced (the original author's signature and source must be marked). Please consciously abide by the open source agreement and jointly maintain the open source environment. It is for DIY and learning purposes only. It is prohibited to use this project for any commercial activities (sales, dissemination, and reproduction for profit), including but not limited to the above three points.
Note! This product is not authorized to any organization! Or for personal sales, if authorized, it will be announced here. Our studio refuses to provide after-sales and technical support for products purchased through other channels.
This is an old-fashioned CSPS power backplane, but with a power signal output interface added (specifically). Please see the circuit diagram for the definition), which can be used to read power information.
The output interfaces of the traditional XT60+
4 pins) and the 12Vsb standby voltage interface for self-made DC-ATX (reserved XH2.54 4P, please see the circuit diagram for specific definitions).
Because the air inlet of this power supply is in the front, so as much as possible while ensuring the strength The shell is hollowed out to increase the air circulation area.
Tested power supplies:
Huawei EPW750-12A 750W
LITEON PS-2461-1H 460W
theoretically supports most so-called "CSPS" server power supplies. The specific interface is subject to short circuit startup. Pins must be '1 and 4'.
Printing shell instructions:
Please see the attachment.
Required mounting screws: M3 x 10mm 16 pcs for fixing the upper cover and bottom plate M3 x 12mm or 14mm 4 pcs for fixing the pcb and bezel
printing note Matters: It is recommended that the upper cover, bottom plate, and baffle be fully filled. It has been designed to be lightweight. It is recommended that the filling of the left and right side panels be no less than 30% .
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:09:34
