zlJ57C
Desktop computer hardware monitoring
The hardware
    is driven by the ESP32-WROOM-32 module, and the SPI method drives the TFT display. The hardware part is relatively simple, with only the ESP32 minimum system plus the TFT display driver. The TFT display is welded. I have tried to use the FPC connector, but it is difficult to weld (my skills are poor). The appearance of the circuit board is the size of the display plus the screw holes around it. The display can be directly glued to the board for fixation.
2023-04-27: AMS1117 was added and the power division was updated. 4.7k pull-up
software was added for CP2102RST
    . The software part is completed with Arduino and driven by TFT_eSPI. The code is attached or linked: https://github.com/gugugu625/HWMonitor
The host computer
    is written in C#, which can automatically detect whether the serial port is the corresponding device and automatically select the appropriate serial port. No selection is required when starting up, which simplifies the process. At the same time, when there are multiple serial ports, it does not affect the use of other serial ports.
The software is attached or linked to: https://github.com/gugugu625/HardwareMonitor625
If you have any questions, please leave a comment.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-04 22:51:12
