kCE3IwQ
Mini 22.5w power bank based on ip5358
22.5w mini fast charger, only 80mm in length!
Yes, you heard it right. The length is only 80mm.
The capacity is 5000mah (of course it is only portable).
C-port input/output
supports most of the fast charging protocols.
Current version 2.0 (3.0 has not been verified yet, but it should be available).
Use two 6mm/7mm M2 The copper pillar is connected, and the C port is welded to the upper plate.
6mm may be a bit tight/7mm requires 26650 batteries (but the current 3.0 version should be able to use 21700).
The 2.0 version requires flying wires, which I discarded directly, so directly placing the 3.0
upper and lower boards requires the use of fpc6pin connections.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 22:55:22
