LrI8v1
Controllable switching regulated power supply developed based on RT9068
Solution selection: Based on the analysis of demand and market research, the RT9068 chip was selected as the core chip for developing a regulated power supply. RT9068 has an efficient PWM control method and a wide input voltage range, which can provide stable power output.
Hardware design: Based on the RT9068 specifications and application guide, the hardware circuit of the regulated power supply is designed. These include input power filter circuits, switching regulator chip circuits, output voltage feedback circuits, etc. Hardware design needs to consider the efficiency of the power supply, the stability of the output voltage, and the ability to respond to load changes.
Software development: The software development of the regulated power supply mainly includes the configuration and control of the RT9068 chip. Using an appropriate programming language and development environment, write software code to set parameters such as output voltage, overload protection, and temperature protection.
Testing and verification: After completing the development of hardware and software, test and verify the regulated power supply. Through actual circuit connection and load testing, the performance and stability of the regulated power supply under different working conditions are verified.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 11:00:24
