张三叔
STM8S208MBSTM32C6T6 smart car
The multifunctional smart car system designed this time uses STM8S208MB and voice parallel as the control core, which are voice wake-up switch, switch low power consumption, mobile phone APP connected to Bluetooth to control the smart car forward, backward, left and right, brake, left turn signal, right turn signal, switch headlight, switch low power mode, shut down, etc., and display the status in real time on the serial port screen. The serial port screen has the functions of switch headlight, switch low power mode, shut down, and after exiting the control interface, you need to enter the password on the homepage to enter the control interface. Through the above discussion, this design can be divided into modules, namely: power module, the system mainly has voice control module, total low power module: field effect tube control low power module, lighting module: field effect tube drive lighting module, execution module: field effect tube control servo low power module, motor drive module, expansion module: unidirectional thyristor control module, triode drive relay module, independent button, LED, buzzer, etc.
Search Datasheet?
Forum More
Update:2025-08-05 03:11:40
