X3LyI5
display fan
Bizhan video link: https://www.bilibili.com/video/BV1Y14y1x76J
I was packing things at home during the summer vacation and found this advertising fan, so I wanted to crack it.
After disassembly, it was found that the original machine used a polished chip. According to the pin definition, it was most likely P89LPC912, a 3V disposable 8051 microcontroller. And the pin definition is very strange, there are 14 pins in total, 4 pins are positive and 11 are negative. So I had to redraw the board and change the chip. I used STC15W408AS. This chip is 5V. Because my fan has also been changed to USB power supply, it can be used.
You can replace it with STC8G1K08. This one is 3V, but it has not been verified. The two models are just different in pin definitions and special function registers. The functions are completely sufficient. The program only uses timers, external interrupts, and comparators. , these three functions. The program needs to slightly change the display delay according to the hardware differences of each fan so that the text is displayed in the middle. The displayed characters occasionally jump after powering on. The reason for this has not yet been found.
When downloading STC-ISP, you need to turn off these functions in the picture. I don't know why. Anyway, when I turn it on, the display is abnormal or even not displayed at all.
If there are any display problems, you can try to use the "fingertip gyroscope" in the accessory to modify it. The fidget spinner is the same program as the fan, but because of its low speed, the effect is better than that of the fan and it will not jump.
Some renderings: (The last one is a fidget spinner, using the same program.)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 02:33:39
