dF1eMz
[Basic Training Camp Class] Touch desk lamp based on SGL8023W +813910A
    1. Click and touch the TI terminal to realize the light switch and output switching functions. The first touch light turns on, the second touch light turns off, and so on. The initial brightness each time the light is turned on
is fixed at the highest brightness, and there is no brightness memory function.
    2. Press and hold the touch button when the light is on (the touch duration is greater than 550ms) to achieve stepless brightness adjustment of the currently lit light. Press and hold once, the brightness of the light will gradually increase. When you release the touch, the brightness of the light will stop at the brightness corresponding to the moment of release. If the time of long press exceeds 3 seconds, the brightness of the light will not change after reaching the maximum brightness; press and hold again, the brightness will stop at the brightness corresponding to the moment of release. The brightness of the light gradually decreases. When you release the button, the brightness of the light stops at the brightness corresponding to the moment of release. If pressed for more than 3 seconds, the brightness of the light reaches the minimum brightness and does not change again. And so on.
    3. If you press and hold the touch button when the light is off, the light will light up at the lowest brightness first. If the touch button is not released,
the brightness gradually increase and start stepless dimming until the touch button is released or the maximum brightness is reached. No more changes.
    4. Click touch and long press touch can be used at any time without interference or restriction of each other's functions.
    5. Turn the sliding potentiometer to achieve color conversion
    6. It is charged by USB 5V and can be connected to a rechargeable battery for long-term use.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:36:34
