QL2jsax6L
ICM42688P High Performance Gyroscope Module
The icm42688p high-performance gyroscope module
code can be found at https://blog.csdn.net/m0_51319483/article/details/126760947.
The attached bin file is for 1000hz serial port transmission of angular velocity, baud rate 230400, format 0x55 0x52 GxH GxL GyH GyL GzH GzL SUM
SUM is the lower eight bits after the previous data is added together. The returned data does not subtract the initial value of the angular velocity of the gyroscope in the static state. Don't forget to subtract it. The data is not filtered either, so you can add a filter yourself.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 17:50:10
  • AMIC 2.4G wireless transceiver chip
  • Next-generation wafer dicing technology
  • Have you bought your ticket home?
  • TMS320F28027 I2C
  • I would like to ask the master to answer this question again. How to adjust the linearity of this power supply?
  • How to fill copper foil
