USbPnfOu36
Mini 0.96 inch 128x64_oled interactive panel
The oled and five-way switch used in the mini interactive panel are as follows:
The oled driver is sdd1312, the link is as follows
https://m.tb.cn/h.UnRyflr?tk=VQGJdS9xT9d
The five-way joystick does not have a pull-up resistor. The connection is as follows
https://m.tb.cn/h.UnRBhgP?tk=ni4UdS9Ced9
Welding and installation precautions:
oled and five-way joystick both lead out 10pin pin headers and FPC interfaces respectively, which can be selected for welding according to different application requirements.
The welded screen can be bonded to the PCB with 3M tape. 3M tape connection: https://m.tb.cn/h.Un8dM3G?tk=440AdSkXHGC
The screen comes with two m3 screw fixing holes, which can be used to fix the PCB.
The five-way button has a designed keycap, and the keycap interface size is slightly larger than the five-way switch, so it may need to be glued with AB glue. The stl file is attached.
Interface definition:
10pin pin header, see the silk screen on the right, the characters are relatively small.
Snake test program:
Use esp32c3 as the main control, and develop using the Arduino platform.
The wiring is as follows:
Interactive panel esp32c3
3.3v---------------vcc
sda----------------gpio4
clk-----------------gpio5
k-r-----------------gpio7
k-l-----------------gpio10
k-u----------------gpio6
k-d----------------gpio3
See the attachment for the Arduino code.
See the attached video for the actual effect:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 15:47:00
