aytwartoofyoroo
2s lithium battery protection board active balancing
Two-string lithium battery protection board with active balancing, over-discharge, short-circuit self-recovery function
Modified from @156135lk's 8.4V@2-string lithium battery protection board active balancing
Attention! ! !
If you need the self-recovery function,
you need to replace the original HY2120-LB with HY2120-OB.
The output MOS tube can be a low-resistance DSOP8 package tube. The tube in the picture is a fake (sad).
Use it with the IP5389 solution of the boss. Two strings and three parallel 18650 are charged at 45w normally.
In addition
, when the protection board is used for the first time, if the battery pack single cell voltage is inconsistent, the board's balancing chip will generate a certain amount of heat when it starts working, and it will basically not heat up in subsequent use.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:10:29
  • The Internet of Things Era
  • CC++ language hardware programming based on TMS320C5000 series DSP
  • How to modify wince key message
  • Looking for an s3c6410, wince6 external interrupt driver
  • Nuvoton MINI51 Seminar
  • Has anyone seen this chip?
