czL6xygK
Convert a violent fan for welding into a vacuum cleaner
I made a control board for the CPU fan. The air volume is OK and the noise is not loud.
The fan I use is a 12V fan with a length, width and thickness of 6cm and a thickness of 3.8mm. I bought it on Taobao for 20 yuan.
The control chip I use is a 555.
I drew a shell myself with SolidWorks.
The sliding rheostat and the resistance value calculation of the resistor need to be calculated.
I used super light clay to cover the air leakage problem. It is a bit ugly.
If you have other questions, you can contact me. I will reply when I see it.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-08 16:38:29
  • How to convert CString to double type
  • f28335
  • Hard Drive Data Recovery
  • EEWORLD University ---- Sensors and Testing Technology
  • PCB wiring standards
  • Help! How can CCS program F149 through FET430UIF emulator?
