Instructions for use
: The chip IP5306 is a power bank chip, which is very cheap and has good performance. However, if it is used to drive a low-power microcontroller, it will lose power after a while and enter sleep mode. So I chose the special version IP5306CK. 1. If necessary, you can also weld the original IP5306, which is fully compatible.
2. The standby current of IP5306CK is relatively large, because it is working continuously, and 1117 also has a certain static current. Therefore, I separated the power supply of 5306 from the battery power supply. If you don't consider power consumption, just short-circuit VCC and BAT+.
3.1117 3.3 and anti-backflow diode do not need to be welded
4. TypeC does not need to be welded, and you can use the vin pin to input 5v charging
The spacing between the two rows of pins: 1415mil The spacing between the two pins: 2mm
Pin
function
description
BAT-
battery negative pole, do not ground, otherwise the battery protection function will fail
BAT+
battery positive pole, used to protect chip sampling
VCC
boost circuit power supply, a switch can be placed between BAT+
KEY
power indicator switch, or you can modify a button-controlled lighting lamp according to the chip information
ground
USBDP
typec
USBDN
typec
5VIN
5V input, connected to TYPEC and chip charging input
5VOUT
boost output
3.3VOUT
LDO output
XB7608AJ https://item.szlcsc.com/2775921.html
IP5306CK is not available in LiChuang Mall, but there are many on Taobao.
These two chips are not difficult to buy, so I won’t put the tb link.
Functional introduction
Advantages
5V2.4A output
2.1A charging
continuous boost, no pulse signal is required (optional), using three-in-one SOC
boost efficiency is high, stable
integrated lithium battery protection chip, overcharge and over-discharge protection
4-level power indicator
integrated AMS1117-3.3V output
2.0 pin header, smaller height
Ultra-low price (except PCB price is below 2.5)
Integrated TYPEC charging port (can not be soldered, leave VI N interface)
to prevent backflow from 5VOUT (but VOUT and VIN cannot be connected)
Limitations
The standby current is 3ma, which is relatively large. The boost part of this power module cannot be used in projects that need to be powered on continuously and are battery-powered. For such projects, it is recommended to use non-CK version chips and use a single-chip microcomputer to simulate continuous key clicks.
Each time the chip is powered on, a key needs to be pressed to activate the chip. The chip
cannot communicate directly with the main control (interested students can study the I2C model of Yingjixin)
Incompatible with perforated boards, 2.0mm holes, can be changed by yourself
### Introduction to IP5306
ip5306-ck is a special version of ip5306, which continuously boosts. This boost board can also use ip5306, but the load needs to meet the requirements or the key pin needs to be continuously activated by PWM signal simulation.
> IP5306 is a multi-function power management SOC with integrated boost converter, lithium battery charging management, and battery power indication, providing a complete power solution for mobile power. > The high integration and rich functions of IP5306 make it only need a few peripheral devices when applied, and effectively reduce the size of the overall solution, > reducing BOM cost. > IP5306 only needs one inductor to realize buck and boost functions. > It can support low-cost inductors and capacitors. > The synchronous boost system of IP5306 provides a maximum output current of 2.4A, and the conversion efficiency is as high as 92%. When no load, it automatically enters the sleep state, and the static current drops to 100uA. > IP5306 adopts switching charging technology, providing a maximum current of 2.1A, and the charging efficiency is as high as 91%. > Built-in IC temperature and input voltage intelligently adjust the charging current. > IP5306 supports 1, 2, 3, 4 LED power display. > IP5306 adopts ESOP8 package.
The circuit diagram is very simple, right! Right!
### Protection chip XB7608AJ
The first and second versions of the protection chip choose Fuman's DW03D. No need to use mos extra. But the price of DW03D is slightly more expensive (5-7 cents), and the price is even higher after the chip surge in 21 years. The schematic diagram and PCB of this part of the second version are as follows
! [Screenshot 2022-09-10 151523](FAFSTSpowerboard1/Screenshot 2022-09-10 151523.jpg)
I chose the XB7608AJ chip. I met him because I saw other products using this chip, and the package felt very strange (CPC5), so I checked it out and felt that the price was very cheap (0.26¥), and the peripheral circuit only needed one resistor and one capacitor, which was easier to weld than dw03d. It is a chip from XySemi Inc. I actually bought some of this chip last year, but I didn't know where I put it. When I revised it, I remembered that there was another chip that could be used. Then use it, hope there is no problem. I did not find the specification book on the official website of the chip, but found the English specification book on LiChuang Mall, which briefly introduces this chip.
The peripheral circuit is extremely simple!
Test
success (minor problems have been fixed)
BOM
ID
Name
Designator
Footprint
Quantity
Manufacturer Part
Jia LiChuang ID
10u
C1,C2,C10,C13
C0805
22u
C3,C4,C5,C6,C7,C8
C0805
0.1u
C9,C11,C12
C0805
SS32
D1
SS34
SS32
C123938
1uH
L1
IND-SMD_L7.0-W6.6_MPCA-0630
SPM6530T -1R0M120
C87572
0805_G
LED1,LED2,LED3,LED4
LED0805_GREEN
NCD0805G1
C84260
2R
R1
R0805
0.5R
R3
R0805
1k
R4
R0805
1K
R6
R0805
10k
R7
R0805
TS-1088R-02026 Small turtle switch
SW1
SW-SMD_L3.9-W3.0-P4.45
TS-1088R-02026
C455280
IP5306CK
U1
ESOP-8-EP
IP5306
INJOINIC
XB7608AJ
U2
CPC -5_L2.6-W2.6-P0.53-LS4.0-BL
XB7608AJ
xysemi (Xysemi)
C2681921
AMS1117-3.3
U3
SOT-223-3_L6.5-W3.4-P2.30-LS7. 0-BR
AMS1117-3.3
AMS
C6186
TYPE-C 16PIN 2MD(073)
USB1
USB-C-SMD_TYPE-C-6PIN-2MD-073
C2765186
