走马观花
RDR-961 - 60 W power supply with InnoSwitch4-Pro PowiGaN, ClampZero and Microchip microcontrollers with ZVS and 5-20 V programmable output
RDR-961 - 60 W Power Supply with ZVS and 5-20 V Programmable Output Using InnoSwitch4-Pro PowiGaN, ClampZero and Microchip Microcontroller
60 W 可编程电源,具有零电压开关 (ZVS) 和 5-20 V 可变输出,使用基于 PowiGaN 的 Innoswitch4-Pro (INN4373F-H341)、ClampZero (CPZ1075M) 和 Microchip™ 微控制器 (PIC16F18325)     InnoSwitch4-Pro数字可控零电压开关反激式开关IC         750 V PowiGaN 开关         有源钳位驱动         同步整流         具有遥测功能的全面保护功能,用于电源状态和故障监控     通用输入:90-265 VAC     可变输出 (3A):5V、9V、15V 或 20V     满足 DOE6 和 CoC v5 2016 平均效率要求,合格率至少为 3.5%         效率高达 93.68%     满足 CoC v5 2016 10% 负载效率要求,所有输出电压条件下均具有高裕度 (>10%)         230 VAC 时空载功耗低于 15 mW     高功率密度:10.73 W/inch3(无外壳)         总共只有 72 个电气元件60 W programmable power supply with Zero Voltage Switching (ZVS) and 5-20 V variable output using PowiGaN-based Innoswitch4-Pro (INN4373F-H341), ClampZero (CPZ1075M) and Microchip™ microcontroller (PIC16F18325)InnoSwitch4-Pro digitally controllable zero voltage switching flyback switcher IC 750 V PowiGaN switchActive Clamp DriveSynchronous RectificationComprehensive protection features with telemetry for power supply status and fault monitoringUniversal Input: 90-265 VACVariable Output (3A): 5 V, 9 V, 15 V or 20 V  Meets DOE6 and CoC v5 2016 Average Efficiency requirements with at least 3.5% pass margin Up to 93.68% efficientMeets CoC v5 2016 10% load efficiency requirements with high margin (>10%) for all output voltage conditions Less than 15 mW no-load consumption at 230 VACHigh power density: 10.73 W / inch3 without enclosure Only 72 total electrical components
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-04 01:20:25
