石榴姐
DER-836 - 30 W USB PD 3.0 power supply with InnoSwitch3-PD PowiGaN with 3.3 V–16 V PPS output (INN3878C-H804)
DER-836 - 30 W USB PD 3.0 Power Supply with 3.3 V–16 V PPS Output Using InnoSwitch3-PD PowiGaN (INN3878C-H804)
30 W USB PD 3.0 Power Supply with InnoSwitch3-PD PowiGaN with 3.3 V–16 V PPS Output (INN3878C-H804) Using InnoSwitch3-PD – Offline QR Flyback Switch IC with Integrated USB Type-C and USB PD Controller , integrated high-voltage switching, synchronous rectification and FluxLink feedback Integrated USB Type-C and USB PD controller reduces footprint and eliminates the need for external microcontrollers Input - 90 VAC – 265 VAC Variable output - 5 V / 3 A, 9 V / 3 A, 12V / 2.5A 15 V / 2 A, 20 V / 1.5 A, 3.3 V – 11 V / 3 A PPS (30 W power limit) output, or 3.3V – 16V/2A PPS30 W USB PD 3.0 Power Supply with 3.3 V–16 V PPS Output Using InnoSwitch3-PD PowiGaN (INN3878C-H804)Uses InnoSwitch3-PD – off-line QR Flyback Switcher IC with Integrated USB Type-C and USB PD Controller, Integrated High-Voltage Switch, Synchronous Rectification and FluxLink feedbackIntegrated USB Type-C and USB PD Controller reduces footprint, no external microcontroller requiredInput - 90 VAC – 265 VACVariable output - 5 V / 3 A, 9 V / 3 A, 12V / 2.5A 15 V / 2 A, 20 V / 1.5 A, 3.3 V – 11 V / 3 A PPS (30 W Power-limited) Output, or 3.3 V – 16V / 2 A PPS
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-08 15:19:07
