ghaytweyhtoo
DER-960 - 100 W USB PD 3.0 + PPS power supply with ZVS using InnoSwitch4-Pro PowiGaN, ClampZero, HiperPFS-5 and Injixin USB Type-C PD controller
DER-960 - 100 W USB PD 3.0 + PPS Power Supply with ZVS Using InnoSwitch4-Pro PowiGaN, ClampZero, HiperPFS-5 and Injoinic USB Type-C PD Controller
100 W USB PD 3.0 power adapter with 3.3 V - 21 V PPS output using PowiGaN-based InnoSwitch4-Pro (INN4375F-H341), ClampZero (CPZ1075M) and HiperPFS-5 (PFS5274F) with Injoinic™ USB Type-C PD control (IP2726S) Zero-voltage switching (ZVS) with active clamp Fixed output: 5V/5A; 9V/5A; 12V/5A; 15V/5A; 20V/5A PPS output: 3.3 V to 21 V / 5 A ( 100 W power limit) Universal input: 90 to 265 VAC 93.35% efficiency at 230 VAC No-load input power <50 mW at 230 VAC High power density: 16.1 W/in³ without enclosure (3.42” x 2.04” x 0.89”) Components Low quantity: 124 in total Fully protected with telemetry for power status and fault monitoring 100 W USB PD 3.0 power adapter with 3.3 V - 21 V PPS output using PowiGaN-based InnoSwitch4-Pro (INN4375F-H341), ClampZero (CPZ1075M) and HiperPFS-5 (PFS5274F) in conjunction with Injoinic™ USB Type-C PD controller (IP2726S)Zero Voltage Switching (ZVS) with active clampFixed output: 5 V / 5 A; 9 V / 5 A; 12 V / 5 A; 15 V / 5 A; 20 V / 5 APPS output: 3.3 V to 21 V / 5 A (100 W power-limited)Universal input: 90 to 265 VAC93.35% efficient at 230 VAC<50 mW no- load input power at 230 VACHigh power density: 16.1 W / in³ without enclosure (3.42” x 2.04” x 0.89”)Low component count: 124 totalComprehensive protection features with telemetry for power supply status and fault monitoring
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-05 15:17:41
