王达业
RDR-942 - 65 W USB PD 3.0 + PPS power supply with ZVS using InnoSwitch4-Pro PowiGaN, ClampZero and Injixin USB Type-C PD controller
RDR-942 - 65 W USB PD 3.0 + PPS Power Supply with ZVS Using InnoSwitch4-Pro PowiGaN, ClampZero and Injoinic USB Type-C PD Controller
65 W USB PD 3.0 power adapter with 3.3 V - 21 V PPS output, active using PowiGaN-based InnoSwitch4-Pro (INN4373F-H341) and ClampZero (CPZ1075M) and Injoinic™ USB Type-C PD Controller (IP2726S) Clamped Zero Voltage Switching (ZVS) Fixed Output: 5V/3A; 9V/3A; 12V/3A; 15V/3A; 20V/3.25A PPS Output: 3.3V to 21V Universal Input: 90 to 265 VAC Efficiency at 230 VAC <25 mW no-load input power at 93.4% at 230 VAC High power density: 15.2 W/in³ without case (2.44” x 2.1” x 0.83” form factor) Low component count: 78 total Fully protected with telemetry, For power status and fault monitoring 65 W USB PD 3.0 power adapter with 3.3 V - 21 V PPS output using PowiGaN-based InnoSwitch4-Pro (INN4373F-H341) and ClampZero (CPZ1075M) in conjunction with Injoinic™ USB Type-C PD controller (IP2726S)Zero Voltage Switching (ZVS) with active clampFixed output: 5 V / 3 A; 9 V / 3 A; 12 V / 3 A; 15 V / 3 A; 20 V / 3.25 APPS output: 3.3 V to 21 VUniversal input: 90 to 265 VAC93.4% efficient at 230 VAC<25 mW no-load input power at 230 VACHigh power density: 15.2 W / in³ without enclosure (2.44” x 2.1” x 0.83” form factor)Low component count: 78 totalComprehensive protection features with telemetry for power supply status and fault monitoring
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-05 16:10:10
