Lemontree
DER-583 - 106 W High Line Input Non-PFC CV/CC Flyback Charger Power Supply
DER-583 - 106 W High Line Input Non-PFC CV/CC Flyback Charger Supply
This engineering report describes a 59 V (nominal), 106 W flyback reference design for operation from 165 VAC to 264 VAC supplies. The power output is designed with constant voltage/constant current characteristics for battery charger applications. The charging circuit is optimized for lead-acid batteries. When the current drops below ~0.5 A during charging, the output voltage switches from the 59 V charge voltage to the 56 V float voltage to keep the battery charged without overcharging. This is a standard feature of lead acid battery chargers. The design is based on the TOP267EG without PFC input stage. It is designed to operate in a fan-cooled enclosure. The design utilizes air splitters to direct cooling air over the main radiator. This minimizes the heat sink size (and device size) required for TOPSwitch U1.
Blockdiagram
Design Files
Search Datasheet?
Forum More
Update:2025-08-03 07:06:27
  • Please give me a program...
  • 12864 Questions
  • How to detect the status of SD card or MMC card in real time under WINCE? ???
  • Do you know the common program architecture of MSP430?
  • Please help me, there is a problem with the reversing radar program!!
  • Correct use of multi-output switching power supply
