念慈菴
DER-660 - 29 W high power factor, isolated flyback LED driver with DALI dimming
DER-660 - 29 W High Power Factor, Isolated Flyback LED Driver with DALI Dimming
This engineering report describes a DALI dimmable, isolated flyback LED driver designed to drive a 36 V, 800 mA LED string over an input voltage range of 180 VAC to 265 VAC. The LED driver uses LYT6067C in the LYTSwitch-6 series of devices. The DER-660 is a high line input flyback converter design with added switching valley fill PFC circuitry. Through the PFC circuit, the design meets the high power factor requirements in LED lighting applications while reducing losses through direct energy transfer. The main design goals are high efficiency, high power factor over the input voltage range and DALI dimming range from 0% to 100%. This document contains power supply specifications, schematics, bill of materials, transformer documentation, printed circuit board layout and performance data
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-09 00:33:29
  • Modify 12864 serial port driver
  • Can Verilog write a test program for UDP?
  • Is ARM certification useful?
  • Development Trends and Advantages of Wireless LAN Front-end Modules (Reposted)
  • Please advise on optical signal stability processing!!
  • W77E58 serial port initialization
