手可摘棉花
ERASynthMicro: USB powered, portable, open source, RF signal generator, supports 12.5MHz - 6.4GHz
ERASynthMicro: USB-Powered, Low-Priced,Open Source,RF Signal Generator
ERASynthMicro is an open source analog RF signal generator that can be powered from a USB port and has an LCD interface for standalone use without a PC. It is equipped with an Arduino Micro microcontroller and a touch display. ERASynth Micro uses advanced PLL/VCO technology combined with an internal ultra-low phase noise frequency reference to form a programmable analog signal generator that can generate low phase noise RF signals from 12.5 MHz to 6.4 GHz. ERASynth Micro uses a dual-loop PLL architecture to provide fast frequency switching and fine tuning resolution. ERASynth Micro also provides frequency, amplitude and pulse modulation capabilities. Frequency tuning and control commands are loaded into the instrument through the serial interface or touch display or Windows GUI. Specifications: Architecture: Dual-loop fractional-N PLL driven by a 10 MHz reference. Frequency range: 12.5 MHz to 6.4 GHzAmplitude range: -50 to +15dBmPhase noise: -115 dBc/Hz @ 1GHz output and 10kHz offsetFrequency switching time: <1msReference: Ultra-low noise 50 MHz VCXO locked to ±500 ppb TCXOMCU: ATMEGA32U4-MU (same as Arduino Microboard)Interfaces:• Touch display module (3.2 inch Nextion NX4024T032)• Micro-USB for power input and serial access• REF IN (SMA) for external reference input• REF Out (SMA) for 10 MHz reference output• RF Out (SMA)• Expansion connectors: External trigger input, external modulation input, microphone input, GPIO (I2C) and SPIDimensions: 57mm x 118mm x 23mmWeight: 120gPower input: 5VPower consumption: 2WCasing: Injection molded plastic caseOpen source: Schematics, Embedded Arduino Code, LCD Screen source code and RS-232 command set Modulation: AM, FM, pulse (internal and external) ERASynthMicrois an open source analog RF signal generator featuring an Arduino Micro micro-controller and atouch display. ERASynth Micro uses advanced PLL/VCO technology, coupled with an internal ultra-low phase noise frequency reference to form a programmable analog signal generator capable of generating a low phase noise signals up to 6.4GHz. ERASynth Micro provides fast frequency switching and fine-tuning resolution using a dual loop PLL architecture. ERASynth Micro also offers frequency, amplitude and pulse modulation capabilities. The frequency tuning and control commands are loaded into the instrument via the serial interface or via Touch Displayor Windows GUI. Feature: Architecture: Dual loop Fractional-N PLL driven by a10 MHzreference. Frequency Range: 12.5 MHz to 6.4 GHzAmplitude Range: -50 to +15dBmPhase Noise: -115 dBc/Hz 1 GHz output and 10 kHz offsetFrequency Switching Time: <1msReference: Ultra-low noise 50 MHz VCXO locked to a±500 ppb TCXOMCU: ATMEGA32U4-MU (same as in the Arduino Microboard)Interfaces:•Touch Display Module (3.2” Nextion NX4024T032)•Micro-USB for power input and serial access•REF IN (SMA) for external reference input•REF Out ( SMA) for 10 MHz reference output•RF Out (SMA)•Expansion connector: External trigger input, external modulation input, microphone input, GPIO (I2C) and SPIDimensions: 57mm x 118mm x 23mm Weight: 120gPower Input: 5VPower Consumption:2WEnclosure: Injection molded plastic caseOpen Source: Schematics, embedded Arduino code, LCD screen source code and RS-232 command setModulation: AM, FM, Pulse (Internal and external)
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-07-06 18:37:30
