12 V, 150 W power supply based on the STNRG011 digital combo and SRK2001 adaptive synchronous rectification controller
The EVLSTNRG011-150 is a 12 V, 150 W power supply demonstration board for 90 V AC to 264 V AC mains, which is an AC/DC converter for All-in-One (AIO) computers or general purpose high power adapters. The design is based on the STNRG011 IC, a digital combination that controls a two-stage AC/DC SMPL. The front end is a transition mode PFC pre-regulator and the second stage is an LLC HB resonant converter. The SRK2001 implements synchronous rectification for higher efficiency. Since the consumption is very low at no load, no auxiliary power supply is required. A full set of auxiliary functions and protections are also provided, which can reduce the overall BOM while maintaining a rugged design. The performance of the EVLSTNRG011-150 meets the requirements of mainstream standard Energy Star® computers ver. 6.1, EuP Lot 6 tier 2, European CoC ver. 5 levels, class 2, with harmonic content well below the limits specified by the European standard EN61000-3-2 class D and the Japanese standard JEITA-MITI class D, in terms of efficiency, no-load input power and power factor. Main Features Digital controller: STNRG011 TM PFC with resonant HB-LLC converter Input voltage range: 90 ÷ 264 V ac 12 V ± 5% CV output regulation Full load power: 150 W continuous operation Peak power load: 200 Watt Full load and average efficiency: greater than 90% at 115/230 V ac Peak efficiency: greater than 93% No-load mains consumption: less than 75 mW Hold-up time: greater than 10 ms Full set of programmable parameters High flexibility thanks to configurable NVM Black box functionality with installed EEPROM
Design Files
Search Datasheet?
Forum More
Update:2025-08-09 06:57:42
