5V/12V Synchronous Step-Down PWM DC/DC and Linear Power Controller
The EV2910ES-00A is an evaluation board for the MP2910ES, which is a dual output with one synchronous buck PWM and one linear controller. This part is used to generate logic supply voltage for PC-based systems. The evaluation board can be turned on or off by a remote EN input referenced to ground. This input is compatible with popular logic devices. This evaluation board also features a power good indicator to comply with the new platform requirements on the Intel® FSB_VTT power platform. The PG port is pulled to ground when the output voltage is less than 10% of its set voltage. Product Features 5V or 12V VCC supply voltage Wide 5V to 20V operating input range 10A output current Fixed frequency 300KHz Internal soft start Output adjustable from 0.8V to 0.9xVIN
Search Datasheet?
Forum More
Update:2025-08-10 21:17:42
