[Open Source Materials for Competition] Electromagnetic Gun Circuit Diagram Design Materials
The circuit diagram of the electromagnetic main power supply and the control part are the same. Each MOS tube can be discharged. The main parameter is the distance and the distance between the photoelectric switch. Use electromagnetic force to push the object to run. Achieve the effect of rapid movement of the object. This data can be up to level 20. Generally, it is difficult to increase the speed to level 14 or higher. The maximum speed is 800M per second. Please do not use electromagnetic guns to hurt small animals. Children should not play! There are calculation tools in the data, and detailed records of each winding distance are recorded at level 7. People with basic knowledge need to understand. Level 7 can penetrate 5CM wooden boards with iron nails, and the farthest distance is about 50 meters. The effective distance is 10~20 meters.
Search Datasheet?
Forum More
Update:2025-08-05 14:31:14
