ohahaha
MAXREFDES1169: ±15V/75mA and ±7.5V/75mA output, ISO-BUCK DC-DC power module
input typeV IN (minimum)
(V)
V IN (maximum)
(V)
I OUT
(A)
Output channelV OUT
(V)
P OUT
(W)
Topology
DC17360.0754 way
±15V and ±7.5V3.375ISO-BUCK
The MAXREFDES1169 is a high-efficiency, iso-buck DC-DC power module based on the MAX17681. It accepts an input voltage range from 17V to 32V and adjusts the output voltage through primary-side feedback. The reference design provides four outputs: ±15V@75mA and ±7.5V@75mA, with a voltage regulation accuracy of ±10%. This iso-buck isolated power module is designed using the MAX17681 in a 10-pin (3mm x 2mm) TDFN package. The MAXREFDES1169 pin spacing complies with the Distributed Power Source Open Standards Alliance (DOSA) open standard for DC/DC module power supplies. Two transformer options are provided, one is from Wurth; the other is from Chinese transformer manufacturer HanRun, which is convenient for users to choose. The reference design provides 1500V electrical isolation.
This circuit board is not for sale.
Key Features
  • ±15V@75mA and ±7.5V@75mA output, output voltage ripple 180mV
  • 17V to 32V input voltage range
  • EN/UVLO input
  • 200kHz switching frequency
  • 89% peak efficiency
  • Overcurrent protection
  • No optocoupler design
  • Output power up to 3.4W
  • Thermal Protection
  • Proven PCB layout
design resources
Design, build and test
This reference design introduces the MAXREFDES1169 hardware circuit design and provides detailed technical guidance for designing iso-buck converters using Maxim's MAX17681A current-mode controller. The power supply has been built and tested.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 23:35:19
