RTL8822BS module peripheral application reference circuit and driver information
For the integration of wifi module, the most urgent things in the early stage are 1: the application reference of wifi module peripheral circuit in hardware 2: the driver information in software
RTL8822BS module RL-SM02F-8822BS application schematic diagram Q42142951.pdf
RTL88x2BS_WiFi_linux_v5.2.21.3_28325_COEX20180430-5e5e.20180614
90046
60W Brushless DC (BLDC) Automotive Motor Driver Design BOM, PCB Files and Gerber Files
The reference design is a BLDC motor controller designed to be powered by a single 12V (nominal voltage) supply with a wide voltage range found in typical automotive applications. The board is designed to drive motors in the 60W range, which requires a current of 5 amps. The size and layout of the board facilitates evaluation of the drive electronics and firmware, with easy access to key signals on various test points. A wide variety of motors can be connected by using a 3-contact connector or soldering the motor phase wires to the plated through holes in the board. The 12VDC supply is fused to prevent damage to the board or bench power supply in the event of a motor failure during testing. Commands and the status of the motor can be transmitted through a standard JTAG connector or through PWM input and output signals. The user can also reprogram the microcontroller through the JTAG connector, allowing customization for various applications. This design forms the solution by incorporating the DRV8301-HC-C2-KIT board.
Schematic/Block Diagram.pdf
Software.zip
Reference Guide.pdf
TIDA-00143 Quick Start Guide.pdf
TIDA-00143 Test Results.pdf
90551
3D printing accuracy test drawings
`3D printing accuracy test drawing machining data
dll.zip
Hot spinning data
20-8-dll.stl
Light curing data
20-8-dll.x_t
3D drawing preview:
dll.zip
20-8-dll.stl
20-8-dll.x_t
90553
Slide block for light-curing 3D printer
5cm stroke shaft slider, contact type single top slider, lead 3mm, screw diameter 3mm. Due to the small size of the components, the recommended process is light curing or milling.
Slider.stl
90554
AP6xxx series Pin to Pin hardware compatible WiFi module peripheral circuit reference
AP6xxx series Pin to Pin hardware compatible WiFi modules, mainly with LGA44/12*12mm and LGA-50/15*13mm package sizes. Currently, we are sharing the peripheral circuit reference of the LGA44/12*12mm series WiFi modules.
AP6xxx series Pin to Pin hardware compatible WiFi modules mainly have two series package sizes: LGA44/12*12mm and LGA-50/15*13mm. Currently, we are sharing the peripheral circuit reference of the LGA44/12*12mm series WiFi modules.
AP6xxx Pin2Pin Reference Design Circuit For Q42142951.pdf
90555
Car battery pack runtime
Despite the growing demand for larger battery cells, battery prices remain quite high, constituting the most expensive component in an EV or PHEV, with a typical price tag of around $10,000 for a battery that supports a range of a few hundred kilometers. The high cost can be mitigated by using lower-cost/refurbished battery cells, but such cells will also have greater capacity mismatches, which will reduce the available runtime or driving distance on a single charge. Even higher-cost, higher-quality battery cells will age and mismatch after repeated use. There are two ways to increase the capacity of a battery pack with mismatched cells: one is to use larger batteries from the beginning, which is not cost-effective; the other is to use active balancing, a new technology that can restore battery capacity in the battery pack and quickly increase power. Full series battery cells need balancing When each battery cell in the battery pack has the same state of charge (SoC), we say that the battery pack is balanced. SoC refers to the current remaining capacity of an individual battery relative to its maximum capacity as the battery is charged and discharged. For example, a 10Ah battery will automatically equalize the state of charge between parallel-connected battery cells over time as long as there is a conductive path between the battery cell terminals. It can also be argued that the state of charge of series-connected cells will vary over time for a variety of reasons. Temperature gradients across the pack, impedance, self-discharge rates, or differences in load between individual cells can cause gradual changes in SoC. While pack charge and discharge currents help to minimize these cell-to-cell differences, the cumulative mismatch will only increase unless the cells are periodically balanced. Compensating for gradual changes in cell SoC is the most fundamental reason to balance series-connected cells. Typically, passive or dissipative balancing schemes are sufficient to rebalance the SoC of cells with similar capacities in the pack.
Maximizing the Runtime of Automotive Battery Packs.pdf
90557
electronic
Search Datasheet?
Forum More
Update:2025-08-03 02:31:08
