Drives two-phase bipolar stepper motors up to 1A DC
The evaluation board for the DMOS fully integrated stepper motor driver L6228Q is presented. The board implements a typical application and can be used as a reference design to drive a two-phase bipolar stepper motor with a current up to 1A DC. Due to the small footprint of the L6228Q (QFN 5 x 5 mm, 32 pins), the PCB is very compact (27 x 32 mm).
en.CD00195549[1].pdf
90563
How to set different output voltages from 10 V to 18 V and how to increase efficiency to 86%
The purpose of this document is to provide information about the STEVAL-ISA081V1 Switch Mode Power Supply (SMPS) demonstration board. The STEVAL-ISA081V1 is an isolated SMPS capable of delivering 12 W output over a wide input voltage range. It is designed to provide a cost-effective and space-saving solution. The STEVAL-ISA081V1 SMPS generates a nominal output voltage of 12 V using primary regulation. The board is based on the VIPer™ 26LD – a monolithic converter integrating a high-voltage MOSFET and a PWM controller. This document contains a basic technical description of the demonstration board (schematic, PCB details and bill of materials) as well as basic measurements (load regulation, efficiency, standby behavior, EMI and thermal behavior data). The last section of this document contains short suggestions on how to set different output voltages in the range of 10 V - 18 V and how to increase the efficiency up to 86%.
en.steval-isa081v1_bom.pdf
90564
USB audio headset design reference circuit diagram
USB audio headset design reference circuit diagram, 32-pin small package TYPE-C headset/Linging headset reference design data, SSS1530 DEMO design reference
SSS1530_QFN32-SSS-20160831.pdf
90565
electronic
Design Files
Search Datasheet?
Forum More
Update:2025-08-02 16:30:33
