Xvy5BRbD
Signal generation and measurement device based on FPGA+STM32
Project Description This project utilizes the iCore4T (STM32H750 + FPGA) core board from Ginkgo Technology to design a signal generation and measurement device. The FPGA handles high-speed DAC acquisition, waveform generation, and multi-channel synchronous data acquisition. The FPGA communicates with the STM32H750 using both serial and SPI communication modes. The FPGA communicates with the STM32H750 via serial port, sending signal frequency, amplitude, and other relevant information. The SPI serial communication module is responsible for sending waveform data. The STM32H750 is primarily responsible for further processing the received data, enabling human-machine interaction via a serial port screen, and simultaneously displaying the waveform on a TFT screen. Additionally, the STM32H750 is extended with an AD9954 module to implement DDS signal generation functionality. Main Design Content This system is based on the iCore4T core controller and integrates signal generation, multi-directional measurement, and display modules. The design mainly focuses on seven parts: system power supply, high-speed ADC acquisition, multi-channel synchronous data acquisition, high-speed DAC, DDS, TFTLCD screen display, and serial port screen display. The contents include: (1) Using a rechargeable lithium battery pack to power the iCore4 core board and its expansion circuits; using a single-channel current-limiting load switch MT9700 to limit the current of the entire system; and providing the corresponding voltages for each module of the system through voltage conversion circuits such as 5V to 3.3V and 5V to -5V. (2) Based on the AD9226 analog-to-digital converter, a signal processing and acquisition circuit is designed to attenuate the voltage to be acquired in the range of -5~+5V to 1~3V and send it to the AD9226 chip for analog-to-digital conversion, and finally send it to the FPGA for acquisition. (3) Based on the AD7606-8 (16-bit, 8-channel synchronous sampling SAR ADC) chip, a multi-channel signal synchronous acquisition function is realized. (4) Based on the 3PD5651E digital-to-analog converter, a signal generation circuit is designed to output an analog voltage signal with adjustable frequency, waveform, and amplitude through the 3PD5651E module. (5) The AD9954 chip is selected to implement the DDS function. The AD9954 module can generate sine signals up to 160MHz and has the function of outputting frequency sweep and frequency hopping signals. (6) A 4.3-inch TFTLCD screen is used to draw and continuously refresh the original or processed signal waveforms, providing an intuitive observation of the signal shape. (7) A 5-inch capacitive serial port screen is used to display signal frequency, amplitude, waveform and other information; human-computer interaction and system control are performed through the serial port interface. (8) The signal processing module is integrated into the iCore4 core board expansion circuit to complete the design and debugging of each module, so that each module works in coordination according to the program instructions to complete the overall system function. Design Principle The design of the entire system is divided into two aspects: software part and hardware circuit design. After the hardware circuit design is completed, the system modules are debugged through the program so that each module works in an orderly manner according to the program design process to realize the functions of waveform generation, signal measurement, and real-time signal display. The overall system block diagram is shown in the figure.
fpga_prj.zip
VisualTFT.zip
PDF_Signal Generation and Measurement Device Based on FPGA+STM32.zip
Altium-based FPGA+STM32 signal generation and measurement device.zip
PADS_FPGA+STM32-based Signal Generation and Measurement Device.zip
BOM_Signal Generation and Measurement Device Based on FPGA+STM32.xlsx
90595
ESP32 3D printer
ESP32 3D printer control board
The ESP32 microcontroller is used as the main controller for a 3D printer. Manual reset is required during programming. Printing can be controlled via Wi-Fi web browser, online printing via a Teyp-C data cable, and offline printing via a serial port display. The stepper motor driver module uses a through-hole design for easy future replacement. The firmware with modified pins is available below.
index.html.gz
Marlin-2.1.2.1.7z
PDF_esp32 3D printer.zip
Altium_esp32 3D printer.zip
PADS_esp32 3D printer.zip
BOM_esp32 3D printer.xlsx
90598
STM32F103C8T6 Minimum System Board
This version uses a TYPE-C interface for power supply and adds CH340, which allows for serial port debugging while using a TYPE-C interface for power supply.
PDF_STM32F103C8T6 Minimum System Board.zip
Altium_STM32F103C8T6 Minimum System Board.zip
PADS_STM32F103C8T6 Minimum System Board.zip
BOM_STM32F103C8T6 Minimum System Board.xlsx
90599
Diwenxing CW32 Digital Voltage and Current Meter Expansion Board
LCSC GeoStar CW32 Digital Voltage and Current Meter Expansion Board
I. Design Background
An ADC (Analog-to-Digital Converter) is an indispensable key component in electronic systems. It converts continuous analog signals into digital signals, enabling digital processing and analysis. ADCs play a crucial role in signal conversion, measurement and data acquisition, control system input, and communication and signal processing. Their widespread application promotes the intelligent and precise control of electronic equipment across various industries, and is one of the key factors driving modern technological progress. A
digital voltmeter and ammeter combines ADC technology with circuit measurement principles, accurately converting analog voltage and current signals into digital displays for easy reading and analysis by electronic engineers. This device not only improves the accuracy and efficiency of circuit measurements but also helps engineers better understand circuit behavior, serving as a powerful tool for electronic design and troubleshooting, and playing a vital supporting role in the work of electronic engineers. In product applications, digital voltmeters ensure the accuracy and safety of circuit design, while also providing strong support for product quality control and subsequent maintenance.
Learning to design and build a digital voltmeter and ammeter is highly beneficial for improving one's professional skills. This digital voltmeter and ammeter project covers multiple aspects, including the design and implementation of microcontroller circuits, the design of signal acquisition and processing circuits, the development and optimization of the user interface, and the design of the product appearance. It integrates knowledge from multiple fields such as electronic technology, microcontroller programming, circuit design, and industrial design.
The project has the following highlights:
It adopts a core board plus expansion board design concept, making learning simpler and exploration more in-depth.
The core board uses the domestic Wuhan Xinyuan Semiconductor CW32 as the main controller, while also being compatible with other similar development boards;
the project has a high degree of integration and strong practicality, and can be used as a desktop everyday instrument after completion.
II. Hardware Design
1. Power Supply Circuit
LDO (Low Dropout Linear Regulator) Selection
This project uses an LDO as the power supply. Considering that most voltmeter products are used in industrial scenarios with 24V or 36V power supplies, this project selected the SE8550K2, which has a maximum input voltage of up to 40V, as the power supply. The main reason for not using a DC-DC step-down circuit to handle the large voltage drop is to avoid introducing DC-DC ripple interference during the design process; a secondary reason is to reduce project costs.
2. MCU Selection Analysis:
This project uses the LCSC CW32F030C8Tx development board (core board) as the main controller. It features
a wide operating temperature range of -40~105℃,
a wide operating voltage range of 1.65V~5.5V (STM32 only supports 3.3V systems),
strong anti-interference capabilities (HBM ESD 8KV), and ESD reliability reaching the highest international standard level (STM32 ESD 2KV).
It also boasts a superior ADC: a 12-bit high-speed ADC achieving ±1.0LSB INL 11.3ENOB, multiple Vref reference voltages (STM32 only supports VDD=Vref),
and stable and reliable eFLASH technology.
3. Voltage Sampling Circuit:
The voltage divider resistors in this project are designed to be 220K+10K, resulting in a voltage division ratio of 22:1 (ADC_IN11). The maximum measured voltage is 30V, and the reference voltage is 1.5V. This reference voltage can be configured through the program. An additional voltage sampling circuit is added to this project. When initially using the ADC_IN11 channel to measure voltages below 30V, if the measured voltage is within 0~3V, the ADC_IN9 channel is used for measurement. At this point, due to the reduced voltage division ratio, the measurement accuracy is greatly improved.
4. Current Sampling Circuit
: The sampling current designed for this project is 3A. The selected sampling resistor (R0) is 100mΩ. Based on the above data, a 100mΩ current sensing resistor was chosen. According to the formula, 3A*100mΩ=300mV, 900mW.
5. OLED Display:
This project uses an OLED display screen as the display unit.
This project uses a 0.96-inch OLED display as the display device. Compared to a digital tube, the OLED can display more data content, and the displayed data content and display method can be changed at will according to the actual use environment. Although the display is easily damaged by external force, this project designed a 3D shell and panel to protect the display. The OLED software is ported from Zhongjingyuan's code.
6. Other circuit
button software design is ported from Anfulai Electronics' scanning independent button, which has a software filtering mechanism and a button FIFO. It can detect the following events:
button press,
button release
, long press
, automatic continuous firing.
Project button function description:
K1 is used for mode switching,
K2 is used for data storage of calibration mode,
and K3 is used to control LED indicator.
This project added an extra TL431 circuit to provide a 2.5V reference voltage, which can be used to provide an external voltage reference for the chip to calibrate the AD.
III. Project Demonstration
CW32F030C8T6_ProjectTemplate.zip
PDF_Diwenxing CW32 Digital Voltage and Current Meter Expansion Board.zip
Altium_Diwenxing CW32 Digital Voltage and Current Meter Expansion Board.zip
PADS_Diwenxing CW32 Digital Voltage and Current Meter Expansion Board.zip
BOM_Diwenxing CW32 Digital Voltage and Current Meter Expansion Board.xlsx
90600
[Microcontroller] Simple Digital Oscilloscope Project Based on GD32
Design a basic, simple oscilloscope using the STM core provided by LCSC development board.
An oscilloscope is an electronic instrument used to measure and display electrical signals. Here are some engineering descriptions of an oscilloscope:
1. Signal Acquisition: It can receive various electrical signals, such as voltage and current.
2. Display Function: It displays the waveform of a signal graphically, intuitively showing the characteristics of the signal.
3. Multi-channel Support: It can simultaneously measure and display multiple signals, facilitating comparison and analysis.
4. Time and Amplitude Measurement: It accurately measures parameters such as the amplitude, frequency, and period of a signal.
5. Trigger Function: Used to stabilize the display of specific signal segments.
6. Storage and Playback: It saves measurement results for subsequent analysis and comparison.
7. Bandwidth and Sampling Rate: These determine the range and accuracy of the signal frequencies it can measure.
8. Signal Conditioning: Such as filtering and amplification, to optimize signal display.
9. Remote Control and Interface: Facilitates integration with other devices and automated testing.
10. Ruggedness: It adapts to different engineering environments and usage conditions.
These characteristics make oscilloscopes widely used in electronic engineering, communications, power, and other fields, helping engineers and technicians analyze and solve various circuit and system problems.
WeChat_20240412002114.mp4
PDF_【Microcontroller】Simple Digital Oscilloscope Project Based on GD32.zip
Altium_【Microcontroller】Simple Digital Oscilloscope Project Based on GD32.zip
PADS_【Microcontroller】Simple Digital Oscilloscope Project Based on GD32.zip
BOM_【Microcontroller】Simple Digital Oscilloscope Project Based on GD32.xlsx
90601
Campus NFC Card
This is an NFC campus card that uses a chip-controlled LED light and features a cool, handcrafted train-themed campus design.
This is a campus NFC card. The chip controls the LEDs to blink. There are four 0805 LEDs on the front. They light up when you swipe the card, but they also work normally without the LEDs. You can use your phone to simulate a campus card by attaching a 3*5mm CUID chip. Tips: The CUID chip can only be read and written using a card reader.
QQ Video 20231011232942.mp4
PDF_nfc-4in1.zip
Altium_nfc-4in1.zip
PADS_nfc-4in1.zip
BOM_nfc-4in1.xlsx
90602
Voltmeter and Ammeter Training Camp
LCSC GeoStar CW32 digital voltmeter and ammeter expansion board. The display uses a 12864 OLED with an IIC interface. The current sampling expansion adds an amplifier, allowing for the acquisition of smaller currents.
Participating in the CW32 Voltage and Current Meter Training Camp to
become familiar with LCSC EDA and Chipsource Semiconductor's CW32 products.
In electronic systems, voltage and current are two fundamental quantities of analog signals. To process these analog signals in digital systems, we need to use an ADC to convert them into digital signals.
ADC, short for Analog-to-Digital Converter, is used to convert analog signals (usually continuously changing voltage or current) into digital signals (usually binary code).
II. Overall Solution
III. Design Summary
This project uses an LDO as the power supply. Considering that most voltage meter products are used in industrial scenarios with 24V or 36V power supplies, this project selected the SE8550K2, which has a maximum input voltage of up to 40V, as the power supply. The main reason for not using a DC-DC buck converter to handle the large voltage drop is to avoid introducing DC-DC ripple interference during the design process; a secondary reason is to reduce project costs.
4. Current Sampling Circuit:
INA199A1DCKR was selected here to amplify the current sampling by 50 times before measurement.
5. OLED Display
6. LED Indicators:
This section includes a power indicator and an IO operation indicator.
7. Button Circuit Design
: Buttons are used for overcurrent settings: KEY1 sets overcurrent to -, KEY2 sets overcurrent to +, and KEY3 restores the default 200mA overcurrent setting. KEY1 and KEY2 have long-press and short-press functions.
IV. Overall Design Block Diagram
V. Program Flowchart
(Refer to Appendix)
VI. Physical Demonstration VII.
Precautions
VIII. Demonstration Video
(See Appendix)
Change Test.mp4
CW32F030C8T6_ProjectV1.0 20240828.zip
Overcurrent settings.mp4
PDF_Voltmeter and Ammeter Training Camp.zip
Altium_Voltage and Ammeter Training Camp.zip
PADS_Voltmeter & Ammeter Training Camp.zip
BOM_Voltage and Ammeter Training Camp.xlsx
90603
LCSC ESP32S3R8N8 Expansion Board V1.0
LCSC ESP32S3R8N8 Expansion Board V1.0 (Replica Version)
This is a reference to an open-source solution: https://oshwhub.com/nan_sheng/esp32s3-tuo-zhan-ban-v1-0.
It describes
an expansion board specifically designed for the LCSC ESP32S3 development board, including USB and lithium battery switching, battery charging, a 0.96-inch OLED, stepper motor driver, LED tri-color lights, digital tube, temperature and humidity sensor, photosensitive sensor, rotary encoder, EEPROM, infrared, and other functional expansions. The video demonstrates software power-on/off, OLED display, and photoresistor ADC voltage reading.
New features:
1. All pins are brought out for easy self-outlining.
2. A 6-layer board is used, with the following layer layout:
signal layer
GND,
5V
GND,
3.3V
GND.
3. Text uses reverse annotation.
4. Originally for personal use and not intended for public release (a copy of someone else's), it is shared here because some group members requested it. Criticism and corrections are welcome.
5. Copyright belongs to the original author. Please go directly to: https://oshwhub.com/nan_sheng/esp32s3-tuo-zhan-ban-v1-0
6. The image below shows a 6-layer precast component, not yet welded; more will be added later.
PDF_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
Altium_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
PADS_LCSC ESP32S3R8N8 Expansion Board V1.0.zip
BOM_LCSC ESP32S3R8N8 Expansion Board V1.0.xlsx
90604
Diwenxing CW32 Voltmeter and Ammeter Training Camp Replica
CW32 voltage and current, replica of the Earth Star development board design
An ADC (Analog-to-Digital Converter) is an indispensable key component in electronic systems. It converts continuous analog signals into digital signals, enabling digital processing and analysis. ADCs play a crucial role in signal conversion, measurement and data acquisition, control system input, and communication and signal processing. Their widespread application promotes the intelligent and precise control of electronic equipment across various industries, and is one of the key factors driving modern technological progress. Digital voltmeters and ammeters combine ADC technology with circuit measurement principles, accurately converting analog voltage and current signals into digital displays for easy reading and analysis by electronic engineers. This device not only improves the accuracy and efficiency of circuit measurements but also helps engineers better understand circuit behavior, serving as a powerful assistant in electronic design and troubleshooting, and playing a vital supporting role in the work of electronic engineers. In product applications, digital voltmeters ensure the accuracy and safety of circuit design, while also providing strong support for product quality control and subsequent maintenance. Learning to design and build a digital voltmeter and ammeter
using a benchtop digital multimeter (Agilent 34401A)
is highly beneficial for improving one's professional skills. This digital voltmeter and ammeter project covers multiple aspects, including microcontroller circuit design and implementation, signal acquisition and processing circuit design, user interface development and optimization, and product appearance design. It integrates knowledge from multiple fields such as electronics, microcontroller programming, circuit design, and industrial design. Considering the learning pace and knowledge absorption capacity of beginners, we have specially launched this introductory-level digital voltmeter and ammeter project, which is very suitable for beginners in electronics and those who want to learn more about microcontroller applications. This project has the following highlights:
it adopts a core board plus expansion board design concept and uses plug-in components, making learning simpler and exploration more in-depth;
the core board uses the domestic Wuhan Xinyuan Semiconductor CW32 as the main controller, while also being compatible with other similar development boards; however, the CW32 has advantages.
The project is highly comprehensive and practical, and after completion, it can be used as a desktop instrument;
the project has abundant learning materials, including circuit design tutorials, PCB design, code programming learning, and training for engineers' debugging skills.
II. Hardware Design
LDO (Low Dropout Linear Regulator) Selection This project uses an LDO as the power supply. Considering that most voltmeter products are used in industrial scenarios with 24V or 36V power supplies, the SE8550K2 with a maximum input voltage of up to 40V was selected as the power supply. The main reason for not using a DC-DC step-down circuit to handle the large voltage drop is to avoid introducing DC-DC ripple interference during the design process, and the secondary reason is to reduce project costs.
To reduce the learning cost for everyone, this project uses the LCSC CW32F030C8Tx development board (core board) as the main controller, but this does not mean that we will talk less about this section. From the perspective of training engineers, the correct selection of the main controller is very important, as it relates to the overall advantage of the project. Regarding the voltmeter and current meter, the author used STM32/CW32 and some other 32-bit microcontrollers for some debugging and testing. This comparison is only with the STM32F103C8T6 as a reference for device selection, primarily aimed at providing ideas and improving understanding.
Avoid blind selection. When selecting an MCU (Microcontroller Unit) for this project, multiple aspects need to be considered to ensure the chosen MCU meets project requirements.
Clearly define your project needs: Understand the required computing power, including clock speed, processor core type, and whether a floating-point unit is needed.
Identify the required I/O ports and important peripherals, such as ADC peripherals. Since this is a development board project, primarily for debugging and learning, there are no strict limitations on the number of I/O ports: i.e., the associated costs are not considered.
Key advantages of the CW32 in this project
: Wide operating temperature range: -40~105℃;
Wide operating voltage range: 1.65V~5.5V (STM32 only supports 3.3V systems)
; Superior interference immunity: HBM ESD 8KV; All ESD reliability meets the highest international standard (STM32 ESD 2KV)
; Project focus - Better ADC: 12-bit high-speed ADC, achieving ±1.0LSB INL 11.3ENOB; Multiple Vref reference voltages... (STM32 only supports VDD=Vref);
Stable and reliable eFLASH technology.
A detailed explanation of these advantages will be provided in the chapters on ADC sampling and related extensions.
The main characteristics of the CW32 ADC: This project requires a focus on the 4 reference voltage sources. (Content from the "CW32x030 User Manual")
The voltage divider resistors in this project are designed to be 220K+10K, therefore the voltage division ratio is 22:1 (ADC_IN11).
The voltage divider resistor selection
is designed to measure the maximum voltage. For safety reasons, this project uses 30V (the actual maximum display value can be 99.9V or 100V).
The ADC reference voltage is 1.5V in this project, and this reference voltage can be configured through the program.
To reduce the power consumption of the sampling circuit, the low-side resistor (R7) is usually chosen as 10K based on experience.
Then, the high-side resistance of the voltage divider resistor can be calculated using the above parameters.
The required voltage division ratio is calculated, i.e., the ADC reference voltage. The input voltage is designed; using known parameters, 1.5V/30V = 0.05 can be calculated.
The high-side resistance is calculated as the low-side resistance/voltage division ratio; using known parameters, 10K/0.05 = 200K can be calculated.
A standard resistor is selected: a resistor slightly higher than the calculated value of 200K is chosen. We usually choose E24 series resistors; therefore, in this project, 220K, which is greater than 200K and closest to the calculated value, is selected.
If, in actual use, the voltage to be measured is lower than 2/3 of the module's design voltage (66V), the voltage divider resistor can be replaced and the program modified to improve measurement accuracy. The following example illustrates this:
Assuming the measured voltage is no higher than 24V and other parameters remain unchanged,
calculations show 1.5V/24V = 0.0625, 10K/0.0625 = 160K. 160K is a standard E24 resistor and can be directly selected, or a higher value 180K can be chosen with some redundancy.
If, in actual use, the voltage to be measured is higher than the module's 99V design voltage, a different resistor can be selected. To expand the voltage measurement range, you can choose to replace the voltage divider resistor or modify the reference voltage. The following example illustrates this:
Assuming the measured voltage is 160V, we can choose to increase the voltage reference to expand the range.
Given that the voltage division ratio of the selected resistor is 0.0145, we can calculate 160V * 0.0145 = 2.32V using the formula. Therefore, we can choose a 2.5V voltage reference to expand the range (increasing the range will reduce accuracy).
Considering the potential fluctuations in the measured power supply, a 10nF filter capacitor is connected in parallel with the low-side voltage divider resistor in the circuit design to improve measurement stability.
(Range switching )
In this project, an additional voltage sampling circuit was added. Therefore, we can discuss the significance of range switching for improving measurement accuracy. Multimeters often have multiple range settings to achieve more accurate measurements. By adjusting different ranges, the optimal measurement accuracy of the measured point within the corresponding range can be obtained.
This project requires a combination of hardware and software to implement this function. When we first use the ADC_IN11 channel mentioned earlier to measure voltages below 30V, if the measured voltage is within 0~3V, then we use the ADC_IN9 channel for measurement. At this time, due to the reduced voltage division ratio, the measurement accuracy is greatly improved. There are many ways to implement range switching; the development board design provides more design possibilities.
This project uses a low-side current sampling circuit for current detection. When learning the common ground between the low-side of the sampling circuit and the development board's meter interface, please do not solder R0!!!
The design analysis
for this project involves a sampling current of 3A, and the selected sampling resistor (R0) is 100mΩ. The selection of the sampling resistor mainly needs to consider the following aspects:
the maximum value of the pre-designed measurement current;
the voltage difference caused by the 3A current sensing resistor in this project; and
the power dissipation of the current sensing resistor, which should generally not exceed 0.5V. A suitable package should be selected based on this parameter. Considering the power dissipation (temperature) issue under high current, a 1W metal wire-wound resistor package was chosen
. The voltage amplification factor across the current sensing resistor is also important. Since no operational amplifier is used to build the amplification circuit in this project, the factor is 1.
The current sensing resistor value can then be calculated using the above parameters
. Since no amplifier circuit is used, a larger sampling resistor is needed to obtain a higher measured voltage for measurement.
Considering that a larger resistor would result in a larger voltage drop and higher power consumption, an unlimited selection of a larger resistor is not feasible.
This project uses a 1W package resistor, corresponding to a power consumption of 1W.
Based on the above data, a 100mΩ current sensing resistor was selected. According to the formula, 3A * 100mΩ = 300mV, 900mW can be calculated.
To cope with different operating environments, especially high-current scenarios, the R0 resistor can be replaced with constantan wire or a shunt. The replacement can be selected according to the actual application scenario. For safety and educational purposes, this project will not discuss measurements exceeding 3A in detail, but the principle is the same.
5. Digital Tube Display
This project uses a digital tube as the display unit.
This project uses two 0.28-inch three-digit common-cathode LED displays as the display device. Compared to a display screen, LED displays offer better visibility in complex environments. The brightness of the LED displays can be increased by using smaller current-limiting resistors, depending on the specific needs of the application environment. Furthermore, LED displays have better mechanical properties and are not as easily damaged by external forces as display screens. They are widely used in industrial applications where stability and reliability are crucial. From a development board learning perspective, this makes it easier to learn electronic measurement principles and related development in a targeted manner.
In this project, actual testing showed that the current-limiting resistors (R1~R6) for the LED displays were configured to 300Ω. The corresponding brightness for both red and blue LED displays was good and the brightness was soft and not glaring.
Strictly speaking, the current-limiting resistors should be added to the segments; adding them to the digits would affect the display effect. Our actual design places them in the digits to save a few resistors, but the impact on the display is not significant. Therefore, we add them to the digits for convenience.
The
driving principle of LED displays mainly involves controlling the switching state of each segment of the LED display to display numbers, letters, or symbols. The following is a detailed explanation of the driving principle:
Basic Structure of a Digital Tube:
A digital tube typically consists of seven or eight LED segments (eight segments in this project). Each segment represents a part of the digital tube and can display numbers 0-9, letters AF, etc.
Digital tubes come in two types: common cathode and common anode. The difference lies in whether the common terminal COM (the end connecting all LEDs) is connected to the negative or positive terminal of the power supply.
Driving Methods:
Segment Selection: The desired number or character is displayed by controlling the on/off state of each segment of the digital tube. Each segment corresponds to a control signal; when the control signal is on, the segment lights up, and vice versa. (a, b, c, d, e, f, g, dp)
Bit Selection: The digital tube to be displayed is selected by controlling the bit lines of the digital tube. Bit line control sets the bit line of the digital tube to be displayed to a high level, and the bit lines of other digital tubes to a low level. By continuously switching the state of the bit lines, the display switching between multiple digital tubes can be achieved.
Driving Circuit:
The driving circuit for a digital tube can be implemented using hardware circuits, such as integrated circuits like digital signal processors (DSPs), microcontrollers (MCUs), or shift registers, to generate control signals suitable for the LEDs.
These control signals can be in the form of pulse width modulation (PWM) signals, serial data signals, etc. By controlling the frequency, width, and amplitude of these signals, the brightness of the digital tube can be controlled, thereby displaying the desired numbers or letters.
Software Control:
In addition to hardware driving circuits, the driving of digital tubes can also be implemented through software control. By programming to generate control signals suitable for the digital tubes, more flexible and complex display effects can be achieved, such as scrolling or alternating display of numbers.
Driving Common Cathode and Common Anode Digital Tubes:
For common cathode digital tubes, the common cathode pin is connected to the negative terminal of the power supply, and the control pin is connected to the output pin of the control chip. When a certain number needs to be displayed, the control chip outputs the corresponding encoded signal to the control pin, causing the corresponding LED segment to light up.
For common anode digital tubes, the working principle is similar to that of common cathode digital tubes, except that the common anode pin is connected to the positive terminal of the power supply, and the control pin is connected to the output pin of the control chip.
Encoded Display:
In order for the digital tube to display the corresponding numbers or characters, the segment data port must output the corresponding character encoding. For example, to display the number "0", the character code for a common anode seven-segment display is 11000000B (i.e., C0H), while the character code for a common cathode seven-segment display is 00111111B (i.e., 3FH). The specific code depends on the actual seven-segment display.
Dynamic and Static Display:
Seven-segment displays can use either static or dynamic display methods. In static display, each of the eight segments of each seven-segment display is connected to an 8-bit I/O port address. As long as the I/O port outputs a segment code, the corresponding character is displayed and remains unchanged. Dynamic display, on the other hand, lights up each segment of the seven-segment display one by one, achieving simultaneous visual display through rapid switching.
In summary, the driving principle of seven-segment displays is to control the switching state of each segment of the seven-segment display to display numbers, letters, or symbols, and to achieve display switching between multiple seven-segment displays through segment selection and digit selection. Furthermore, the driving of seven-segment displays can be implemented through hardware circuits or software control, and common cathode or common anode seven-segment displays can be selected as needed.
This project actually uses dynamic scanning display to drive the seven-segment display.
To estimate the current required for the digital tube display,
this project actually uses dynamic scanning to drive the digital tubes. Therefore, at any given time, only a maximum of 8 segments of the digital tube (or LEDs) can be lit, or in other words, only one digit can be lit. According to the design, the required driving current is approximately 11mA, which is the high-level voltage of the I/O port: 3.3V ÷ 300Ω.
At this point, it is important to ensure that the selected MCU has sufficient current-source/current-sinking capability.
Analysis of the datasheet shows that the CW32 has no issues. (Some chips do not work.)
6. LED Indicators
This project additionally designed a power indicator and an I/O operation indicator.
LD_PWR is the power operation indicator
. Since the chip's I/O often has a greater current sinking capability than a current pulling capability, LED1 is designed to be active low (on).
To reduce the current consumption of the LED, some LED brightness is sacrificed, the number of component parameters is reduced, and the current-limiting resistor for the LED is selected as 10K.
There are various design methods for the button control circuit. Thanks to the fact that the CW32's I/O port can be configured with pull-up and pull-down resistors internally, the button control circuit on the outside of the chip does not need to be configured. One end of the button is connected to the MCU's I/O, and the other end is grounded. When the button is pressed, the I/O is pulled low.
8. TL431 Circuit Design for Voltage Measurement and Calibration:
This project adds an extra TL431 circuit to provide a 2.5V reference voltage. This can be used to provide an external voltage reference for the chip to calibrate the AD converter. From a product design perspective, due to the inherent ADC performance advantages of the CW32, this circuit is not necessary. This circuit is designed on the development board to learn the relevant application principles.
The TL431 is a relatively "old" device, a classic, and widely used one, still found in many electronic products.
Many beginners may be encountering this device for the first time, so we will briefly explain its principles to help everyone better apply the TL431.
TI defines it as a "Precision Programmable Reference." On the first page of the references, we can focus on several key characteristics.
Precision: Precision indicates that its output voltage is very accurate. I used a ±0.5% accuracy TL431, which measured 2.495V on the board at room temperature. Compared to common Zener diodes, the accuracy is vastly different. In the application circuit diagram, the TL431 is represented by a Zener diode symbol.
Adjustable Output Voltage: The adjustable output voltage is between Vref and 36V. In our project, we use the output Vref voltage, which is approximately 2.5V. Therefore, we use 2.5V in the description, which is approximately equal to Vref.
Sinking Current Capability: This refers to how much current the output voltage pin can provide. This is greatly influenced by the resistance value (R13) in the application circuit. It should not be less than 1mA. If there is no need for sinking current, do not design the current to be too high, as this will cause unnecessary power consumption.
Demo video.mp4
PDF_Diwenxing CW32 Voltage and Current Meter Training Camp Replica.zip
Altium_Diwenxing CW32 Voltage and Current Meter Training Camp Replica.zip
PADS_Diwenxing CW32 Voltage and Current Meter Training Camp Replica.zip
BOM_Diwenxing CW32 Voltage and Current Meter Training Camp Replica.xlsx
90605
Street light energy-saving control system
 The street light energy-saving control system
integrates the following components:
SRD-12VDC-SL-C
KM228M025J20RR0VH2FP0
CGA0603X7R104K500JT
RM065-503(50K)
FRC0603J202 TS
03EC0575
ERS1HM100D11OT
204-10SURD/S530-A3
NE555DR
S9012 2T1(RANGE:200-350)
S9013 J3(RANGE:200-350
) GL5528(10-20)
DB301V-5.0-2P-BU-S
CD4011BM/TR
b9f1482745288e7c651cf3fc0eb56363.mp4
PDF_Street Light Energy-Saving Control System.zip
Altium Street Light Energy-Saving Control System.zip
PADS_Streetlight Energy-Saving Control System.zip
BOM_Streetlight Energy-Saving Control System.xlsx
90607
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 12:15:03
