YYmRsx
STM32F030/051 development board
Used for evaluation or application development of STM32F051C8T6 microcontroller. Compatible with STM32F030C8T6.
Has the following characteristics:
  • All IO interfaces are drawn out, and the onboard CH340C USB to serial port chip makes it easy to download programs or perform serial communication with a PC.
  • BOOT0 chooses to use a toggle switch to avoid the trouble of plugging and unplugging jumper caps.
  • Uses micro-usb, easy to find wires
  • Reserved SWD interface, which can be connected to ST-LINK for debugging
  • The PA4 (DAC output) interface uses an LM358 operational amplifier as a voltage follower to improve its port driving capability.
  • Two touch buttons and 3 LEDs are onboard to facilitate program debugging.
  • The onboard LCD1602 interface and a TFT LCD interface are compatible with most display modules you can buy online.
  • Use supercapacitor as RTC backup power supply to avoid the trouble of replacing batteries
  • USB interface has 500mA overcurrent protection
  • Multiple power test points on board for easy testing with an oscilloscope or multimeter
Please note
  • The sample code is based on the latest HAL library of STM32, uses STM32CubeMX to generate initialization code, and is developed under trueSTUDIO, and the compiler is GCC.
  • My board uses a 12MHz crystal oscillator. If you use a crystal oscillator with other frequencies when soldering by yourself, please modify the RCC configuration according to your own crystal oscillator frequency (it is recommended to use STM32CubeMX for modification)
  • In the RTC sample code, I use the uncommon 1601 display. If you use 1602, please make the corresponding modifications in the LCD_Config.h file yourself.
Welding finished product renderings: snipaste_20191010_170004.jpg
Drive 0.96-inch 160x80 IPS TFT display effect through hardware SPI (display control IC: ST7735) snipaste_20191010_165853.jpg
Example of generating a 1kHz sine wave through the 12-bit DAC built into the STM32F051 snipaste_20191010_165935.jpg
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 04:21:56
  • Wince driver interruption problem
  • 6U CompactPCI
  • Why do I use int to declare variables when using EEPROM, but there are only 255 of them?
  • Power supply noise interference processing
  • Can the register secondary latch be latched correctly?
  • TI's BQ2057 charging current is only 200mA. Please give me some advice based on the picture above!
