Official introduction: https://www.wch.cn/products/CH32X035.html
![Screenshot 2024-08-13 162105.png]
![IMG_20240813_162737 - Copy.jpg]
PDF_CH32X033 Development Board.zip
Altium_CH32X033 Development Board.zip
PADS_CH32X033 Development Board.zip
BOM_CH32X033 Development Board.xlsx
93169
USB-powered touch-sensitive dimmer light
Simple LED fill light
It uses the SGL8022W touch chip, which features dimming and memory functions without power interruption. The five 26mm ceramic LED
touch area pins can be soldered to the back, making it convenient
to use as a simple fill light.
WeChat_20240813123056.mp4
PDF_USB Powered Touch Dimmer.zip
Altium_USB-powered touch dimmer light.zip
PADS_USB Powered Touch Dimmer.zip
BOM_USB Powered Touch Dimmer.xlsx
93170
CD Reader - GL823K
TF card reader with digital record function
The cover is a rendering of Jie Jie's Revelation, which I absolutely love.
The background is
from a recent project I was working on, and I realized I needed a good card reader, so I made this project.
The main controller
uses a Skyworth GD823K ,
and the casing design
uses the Fusion360 design, with an appearance resembling a record. Black material is recommended for printing.
The top shell has a hole for placing the printed record on the panel.
M23 or M24 flathead screws are suitable for the connectors.
Tips: The panel printing file can be directly modified in LCSC EDA. Images can be quickly created using Photoshop or PowerPoint; simply make them circular, export them as PNGs, and import them with a diameter of 27mm. The two bottom parts are for placing the record; please select a thickness of 1.5mm.
Other links
: Bilibili video: https://www.bilibili.com/video/BV1Nr421F7KU/
The open-source files should be completed by June 30th and will be attached.
1.5 screw hole .stl
1.5 threaded hole (under .stl)
PDF_Card Reader - GL823K.zip
Altium CD Reader - GL823K.zip
PADS Record Reader - GL823K.zip
BOM_Record Reader - GL823K.xlsx
93171
electronic
