OvW31
PCB Bookmark 2nd Generation (USB-HUB + Card Reader)
This is a PCB bookmark/USB-HUB + card reader based on SL2.1A and GL823K-HCY04.
The USB-HUB only has two ports mainly for aesthetic reasons; the punched holes in the USB-A female connector are a bit obtrusive, since most people use it as a bookmark. It could be expanded to have four ports.
PDF_PCB Bookmarks 2nd Generation (USB-HUB + Card Reader).zip
Altium_PCB Bookmarks 2nd Generation (USB-HUB + Card Reader).zip
PADS_PCB Bookmarks 2nd Generation (USB-HUB + Card Reader).zip
BOM_PCB Bookmarks 2nd Generation (USB-HUB + Card Reader).xlsx
94017
USB triaxial magnetic field sensor electronic compass
The 0.91-inch OLED screen displays the direction and angle of the three-axis magnetic field in real time. It can be used simply by plugging in a 5V USB power supply. A download port is reserved for easy modification and download of the microcontroller program later.
LCSC EDA Professional Edition design schematic and PCB layout;
USB powered, it displays the three-axis magnetic field direction angle on a 0.91" OLED screen upon plugging in;
supports serial communication, with 9600, N, 8, 1 communication data transmitted as plaintext strings for easy reading and processing by the host computer
; the host computer for displaying the three-axis magnetic field direction data developed using LabVIEW programming;
the data format displayed by the serial port assistant;
a reserved download port for subsequent modification and download of the microcontroller program, using STC8G1K08A as the microcontroller master and CH340N as the USB communication chip.
Welcome to leave comments and exchange ideas!
LabVIEW three-axis magnetic field sensor monitoring system host computer.vi
USB three-axis magnetic field lower-level microcontroller uVision Keil source code.zip
PDF_USB Triaxial Magnetic Field Sensor Electronic Compass.zip
Altium_USB Triaxial Magnetic Field Sensor Electronic Compass.zip
PADS_USB Triaxial Magnetic Field Sensor Electronic Compass.zip
BOM_USB Triaxial Magnetic Field Sensor Electronic Compass.xlsx
94018
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 08:16:35
