aDgfw
LM2596 power supply circuit
Using an LM2596 5.0 to step down from 24V to 5V, and using an LDO to step down to 3.3V.
PDF_LM2596 power supply circuit.zip
Altium_LM2596 power supply circuit.zip
PADS_LM2596 power supply circuit.zip
BOM_LM2596 Power Supply Circuit.xlsx
94319
AD8099 High-speed op-amp
High-speed amplifier circuit based on AD8099
A high-speed amplifier circuit with 10x gain built using AD8099
has been verified. At 100MHz, it can amplify a 100mV peak-to-peak sine wave to approximately 900mV.
Single-sided routing is convenient for manual PCB fabrication.
Note: The SMA interface should be BWSMA-KE-PO01 (searchable on LCSC).
AD8099 chip introduction: Ultra-low distortion, high speed, 0.95NV/√Hz voltage noise operational amplifier; at a gain of 10, bandwidth up to 550MHz, slew rate up to 1350V/µs.
AD8099 High-Speed ​​Operational Amplifier_2024-06-10.epro
PDF_AD8099 High-Speed ​​Op-Amplifier.zip
Altium_AD8099 high-speed op-amp.zip
PADS_AD8099 High-Speed ​​Operational Amplifier.zip
BOM_AD8099 High-Speed ​​Op-Amplifier.xlsx
94320
Summer Dragonflies
The spring flows silently, its gentle stream cherished; the shade of the trees reflects on the water, loving the soft sunshine. A tiny lotus bud just begins to emerge, and a dragonfly has already alighted on it. Create a summer dragonfly LED light.
The spring flows silently, its gentle stream cherished; the shade of the trees reflects on the water, loving the soft sunshine. A tiny lotus bud just begins to emerge, and a dragonfly has already alighted on it. Create a summer dragonfly LED light. Control the different flashing effects of the LED light using buttons.
petal_20240530_234533.mp4
PDF_Summer Dragonfly.zip
Altium_SummerDragonfly.zip
PADS_Summer Dragonfly.zip
BOM_Summer Dragonfly.xlsx
94321
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 19:32:21
