7MCBh
Heart-shaped flowing water lamp
Note!!! This project was copied and pasted from another project (I was too lazy to redraw it). There might be some issues when converting from schematic design to PCB, but the connection between the schematic and PCB is absolutely fine (I can't guarantee the routing is up to standard). It has been verified in a physical device. The program source code is referenced from Bilibili user: Xiaobaiyun's Bilibili video (released April 3, 2023, titled "Flowing Lights"). (Contact me to remove if there is any copyright infringement). The attached file contains the HEX file of the program from the video; after downloading, you can directly use STC-ISP to burn it into your microcontroller.
WeChat_20240416220506.mp4
heart_lamp.hex
PDF_Heart-shaped Flowing Water Lamp.zip
Altium_Heart-shaped Flowing Light.zip
PADS_Heart-shaped Flowing Light.zip
BOM_Heart-shaped Flowing Light.xlsx
95192
MT3608 boost module
The wiring layout of an MT3608 boost module may not be standard; please refer to it with caution.
The actual product has been tested and verified to be usable. The 100kΩ sliding rheostat in the circuit diagram can be replaced with a 10kΩ rheostat. Please adjust the voltage boost rate according to your needs.
PDF_MT3608 boost module.zip
Altium_MT3608 boost module.zip
PADS_MT3608 boost module.zip
BOM_MT3608 boost module.xlsx
95193
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 11:04:36
