Real-time adjustment of the servo angle of the Yiweilian light switch device via serial port
Real-time adjustment of the servo angle of the Yiweilian light switch via serial port. This is a video demonstration of controlling it. [https://oshwhub.com/liujianqi1688/dan-pian-ji-guan-deng-shen-qi-lan-ren-kai-guan](https://oshwhub.com/liujianqi1688/dan-pian-ji-guan-deng-shen-qi-lan-ren-kai-guan
) The program can be downloaded directly (latest optimization as of November 20, 2024; one servo can be adjusted to three angles, highly recommended).
Below are the parameters for two servos installed on either side of the switch panel for on and off (for reference only). The angle can be fine-tuned according to the site conditions.
//The source code and PCB for the above work are publicly available. Search for the username "奇奇爱上单片机" on the "LCSC Open Source Hardware Platform".
//Microcontroller model: STC8G1K08 //1. When burning the program, be sure to select built-in IRC=30MHz. //2. Change the IRC debugging mode to "Do not adjust, use the internal preset frequency". //2. Set the reset pin to the IO port. //3. Uncheck "Erase user EEPROM area when downloading user program".
/*No technical support provided, just sharing for fun.*/ This is an open-source blogger's work; it is for use only and not for commercial purposes. For any questions, please discuss in the comments section below. Designer of this solution: Qiqi (
TikTok: The Cutest Mr. Qiqi in the Universe; Kuaishou ID: Qiqi Loves Microcontrollers; Bilibili: Qiqi Loves Microcontrollers); QQ: 1715755109 (For custom microcontroller programs and PCB designs, please add me as a friend and indicate your purpose. Paid design services are available; serious inquiries only). QQ Group: 499067314 (Welcome all microcontroller enthusiasts to join the group; group files and materials are available for free download).
STC burning software download requires specific settings. (bmp)
The latest program optimization (20241120) allows for three adjustable angles with a single servo motor; highly recommended.zip
PDF_Digital Tube Rotary Encoder [Serial Communication Adjustable Servo Motor with Three Angle Values].zip
Altium Digital Tube Rotary Encoder [Serial Communication, Adjustable Servo Motor with Three Angle Values].zip
PADS Digital Tube Rotary Encoder [Serial Communication, Adjustable Servo Motor with Three Angle Values].zip
BOM_Digital Tube Rotary Encoder [Serial Communication Adjustable Servo Motor with Three Angle Values].xlsx
