ypKO1CVHL5
MPU6050 IMU module 30mm small board
PDF_MPU6050 IMU Module 30mm Small Board.zip
Altium_MPU6050 IMU module 30mm small board.zip
PADS_MPU6050 IMU module 30mm small board.zip
BOM_MPU6050 IMU Module 30mm Small Board.xlsx
95538
TPS5450 DC-DC power module 30mm small board
TPS5450 DC-DC power module 30mm small board main parameters: Input voltage 5.5V~36V; Output voltage 1.22V~35V; Accuracy 1.5%; Continuous output current 5A; Maximum output current 6A; Power efficiency >90% [FB voltage 1.2V]. For detailed parameters, please refer to the chip datasheet.
PDF_TPS5450 DC-DC power module 30mm small board.zip
Altium_TPS5450 DC-DC power module 30mm small board.zip
PADS_TPS5450 DC-DC power module 30mm small board.zip
BOM_TPS5450 DC-DC power module 30mm small board.xlsx
95539
RP2040 30mm small board
The RP2040 30mm small board
features onboard Flash, a debug interface, and a USB interface,
and provides commonly used interfaces (but no ADC).
It has been verified and tested.
PDF_RP2040 30mm small board.zip
Altium_RP2040 30mm small board.zip
PADS_RP2040 30mm small board.zip
BOM_RP2040 30mm small board.xlsx
95540
ESP32 30mm small board
chip: ESP32-PICO-D4
USB-TTL: CH343p
Common interfaces are provided
, and it can be used as a network node
. This has been verified and tested.
PDF_ESP32 30mm small board.zip
Altium_ESP32 30mm small board.zip
PADS_ESP32 30mm small board.zip
BOM_ESP32 30mm small board.xlsx
95541
AL5125 (I2S output firmware) + ES9018K2M + OPA4134 + TPA6120A2RG portable Bluetooth LDAC and USB decoding headphone amplifier
This headphone amplifier is based on the aluminum alloy casing of the ANMAZZ HP2 headphone amplifier. It supports two 3.5mm jacks for separate or simultaneous output, Bluetooth and USB modes, and the USB port supports Hiby Music's exclusive USB function. The total power consumption is approximately 130mA~150mA.
       The previous two projects, "Type-C Powered Portable 47mm Headphone Amplifier - JLCPCB EDA Open Source Hardware Platform (oshwhub.com)" and "Type-C Portable Decoding Headphone Amplifier - JLCPCB EDA Open Source Hardware Platform (oshwhub.com)," were built and open-sourced based on the aluminum alloy casing of the ANMAZZ HP2 headphone amplifier. Both amplifiers perform well overall. However, considering that the Type-C Powered Portable 47mm Headphone Amplifier - JLCPCB EDA Open Source Hardware Platform (oshwhub.com) lacks decoding capabilities, and the Type-C Portable Decoding Headphone Amplifier - ... The JLCPCB EDA open-source hardware platform (oshwhub.com) occasionally experiences issues such as USB disconnections and the inability to play content exclusively via USB on the HiBel player, and wired use is not very convenient. Therefore, I considered creating a headphone amplifier that supports LDAC Bluetooth decoding. After referencing various sources, I came up with a combination solution of AL5125 + ES9018K2M + OPA4134 + TPA6120A2RG. Later, to increase the fun of DIY, I designed and prototyped the casing myself, and the result is quite good. The casing file is attached. Please carefully read the attached documents before making the PCB and casing prototypes.
       The design references the high-fidelity portable Bluetooth headphone amplifier (PCM1794A + TPA6120 solution) - JLCPCB EDA open-source hardware platform (oshwhub.com) and the ES9018 DAC decoding board - JLCPCB EDA open-source hardware platform (oshwhub.com).
        After pairing with the AR5B22 Bluetooth adapter on a Xiaomi 6, Huawei Mate 30 Pro, Huawei Honor 10, Apple 13 Pro, Apple 5S, and a laptop, the performance was acceptable. The Xiaomi 6 and Huawei Mate 30 Pro support Bluetooth LDAC, the Apple phone supports Bluetooth AAC, and the Huawei Honor 10 supports Bluetooth APTX. When the computer's USB is connected and Bluetooth is turned on and connected, Bluetooth will be prioritized by default. When the computer's Bluetooth is turned off, it will automatically switch to USB decoding. Based on the past year of use, there may be a slight background noise when the headphone cable touches the Bluetooth antenna. I'm not sure if this is caused by the Bluetooth signal passing through the headphone cable and entering the internal circuitry. However, when the headphone cable touches the Bluetooth antenna and there is background noise, touching the Bluetooth antenna with your hand will make the background noise disappear. In actual use, I don't think this background noise is a big problem, since the background noise is masked when the music is playing. Alternatively, you can separate the headphone cable from the Bluetooth antenna. After testing with 16-ohm, 32-ohm, and 300-ohm small headphones, as well as 50-ohm large headphones, it felt okay. It can drive two 16-ohm headphones simultaneously. The AL5125 module has a 2.8V low-battery warning. It's said that an LED will flash and an audible warning will sound when the battery voltage drops to 2.8V. However
         , in practice, using the battery in the ANMAZZ HP2 headphone amplifier, it automatically shuts down when the voltage drops to 3V. The TPS65133DPDR's input voltage range is 2.9V~5V, so the 2.8V low-battery warning set in the AL5125 firmware is meaningless. The aluminum alloy casing in the picture is a modification of the original ANMAZZ HP2 headphone amplifier. For aesthetic purposes, I engraved some patterns myself. Another one is my own design. For personal DIY, the production cost is probably around 160 RMB.
TYPE-C interface rechargeable portable Bluetooth decoding headphone amplifier.zip
PDF_AL5125 (I2S output firmware) + ES9018K2M + OPA4134 + TPA6120A2RG Portable Bluetooth LDAC and USB Decoding Headphone Amplifier.zip
Altium_AL5125 (I2S output firmware) + ES9018K2M + OPA4134 + TPA6120A2RG portable Bluetooth LDAC and USB decoding headphone amplifier. zip
PADS_AL5125 (I2S output firmware) + ES9018K2M + OPA4134 + TPA6120A2RG Portable Bluetooth LDAC and USB Decoding Headphone Amplifier.zip
BOM_AL5125 (I2S output firmware) + ES9018K2M + OPA4134 + TPA6120A2RG Portable Bluetooth LDAC and USB Decoding Headphone Amplifier.xlsx
95543
YBA-AMS
YBA-AMS Test Development Board PCB
CH connects to the motor; the pin marked with a down arrow (⬇) connects to the bottom of the motor.
SW connects to the common and middle pins of the microswitch; U is the top pin, D is the bottom pin, pin distinction is not important.
M connects to the manual switch; + is for feeding, - is for unloading. When using
the DRV8833 motor drive module with the bottom facing up and
powered by the microcontroller's 5V interface, the bottom 5V-VCC needs to be shorted. In this case, there is no need to solder the step-down module to the DC socket.
All connectors are 2.54mm; you can choose according to your personal preference
. ![IMG_20240324_221757.jpg]
PDF_YBA-AMS.zip
Altium_YBA-AMS.zip
PADS_YBA-AMS.zip
BOM_YBA-AMS.xlsx
95544
NE555_12V Dual-color LED Strip Driver
I have too many NE555s on hand, I'll find a project to use some of them.
    The schematic for this project comes from @画板当吃生菜's "Analog Circuit: Dormitory Lamp Switch Dimming Circuit". I added a 12V trigger circuit to the original project, which can request 12V voltage from charging heads that support the PD protocol. Because a 6-pin Type-C interface is used, this project can only activate the 12V using a double-ended Type-C data cable.
    The casing comes from the open-source hackledpro from HACK Labs.
hackledprd's 3D shell.zip
BOM_NE555_12V Dual-color LED Strip Driver.xlsx
95545
Copying the ESP32 sepak takraw light setup: main control board plus light board
This project, which involves copying existing work, is already in its third iteration and hasn't been validated yet. Be extremely cautious when replicating! Be extremely cautious when replicating! Be extremely cautious when replicating!
This is a project I copied, and it's the third version of the solution, still untested. Be careful when replicating! Be careful when replicating! Be careful when replicating!
Reference projects: 1. Espressif - Voice-activated Vine Ball Lamp Project 2. Full-color RGB Smart Fill Light - Warm and Cool Light Adjustment.
Since there was no outer casing, I used LaserMaker to draw the casing design and made a casing from laser-cut wood. The result looks pretty good. I'll share the casing design file here.
The casing still has many unreasonable aspects (mainly the size of the USB port and the screw holes), so be careful when replicating!
Night light casing.lcp
PDF_ESP32 Sepak Takraw Light Homework Copying, Main Control Board and Light Board.zip
Altium_ESP32 Sepak Takraw Light Homework Copying - Main Control Board and Light Board.zip
PADS_ESP32 Sepak Takraw Light Homework Copying - Main Control Board and Light Board.zip
BOM_ESP32 Sepak Takraw Light Homework Copy, Main Control Board and Light Board.xlsx
95546
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 17:59:21
