yO9n3
Pull-up potentiometer adapter board
This functional description
applies to most pull-up potentiometers and microphones.
Currently verified to be compatible with Epiphone microphones with correct wiring.
Manufacturing notes:
Board thickness 1.0mm; note that half-hole manufacturing is not permitted.
Open Source Notice:
This project is licensed under the CC BY-NC 3.0 open source license; please see the link for details.
You are free to: Share — reproduce, distribute, adapt, modify, transform, or create based on this work
in any form or medium. As long as you comply with the terms of the license agreement, the licensor cannot revoke these rights. However, you must comply with the following conditions: Attribution — You must give appropriate attribution, provide a link to this license agreement, and indicate whether modifications were made (to the original work). You may use any reasonable means of attribution, but you must not in any way imply that the licensor endorses you or your use. Non-Commercial Use — You may not use this work for commercial purposes. No Additional Restrictions — You may not use legal terms or technical measures to restrict others from doing what is permitted under this license agreement. Disclaimer: You are not obliged to comply with the license agreement due to elements of the work in the public domain, or your use is permitted by applicable exceptions or limitations. No warranties are provided. The license agreement may not grant all the necessary permissions for your intended use. For example, other rights such as image rights, privacy rights, or moral rights may restrict how you use the work.
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 18:56:15
