gEV1yYpKu
IC_card
wx_camera_1699697504400.mp4
PDF_IC_card.zip
Altium_IC_card.zip
PADS_IC_card.zip
BOM_IC_card.xlsx
95808
Canokey STM32 A+C Edition
Canokey STM32 version implements USB A+C dual interface
Canokey is an open-source hardware keying device that supports FIDO2, OATH, OpenPGP, PIV, and other functionalities. It achieves an experience almost identical to Yubikey at a lower cost, significantly enhancing the security of digital assets.
This project is based on the Canokey STM32 nano version and implements a USB A+C dual-interface design.
Official website: https://canokeys.org/
Hardware reference: canokeys/canokey-hardware (github.com)
Firmware reference: canokeys/canokey-stm32: An open-source USB security token powered by STM32 (github.com)
Note: This project is only for low-cost experience with Canokey, or for learning, testing, and research. The STM32 version of Canokey offers no security whatsoever; the private key can be exported. Do not use it in a production environment!
A secure version of Canokey can be obtained here:
After attaching the original Canokey Pigeon, you can apply a layer of AB glue and then shape it as desired.
PDF_Canokey STM32 A+C version.zip
Altium_Canokey STM32 A+C version.zip
PADS_Canokey STM32 A+C version.zip
BOM_Canokey STM32 A+C Version.xlsx
95809
Makita 5-cell battery pack with 60W USB fast charging, supports same-port charging and discharging.
Important Notes on the Solution
: 1. The IP2366 is a 140W charging chip. However, this 140W means it supports a maximum of 140W fast charging protocols. The specific charging power will be determined by the materials and layout of the external step-up/step-down MOSFETs and inductors. Different power ratings result in different circuit costs.
2. The MOSFETs used with the IP2366 cannot be easily replaced. This solution uses a maximum charging power of 60W, and it can only stably pass high-temperature testing with a heatsink. Therefore, applications without a heatsink will be limited to 45W to avoid product risks. The mature implementation of a MOSFET requires careful temperature testing and load testing on a small batch of boards before it can be judged, resulting in a long testing cycle.
Reference Circuit
PCB Layout Diagram
PCB 3D Preview Diagram
PCB Physical Image
Download Data:
https://oshwhub.com/saber.lily
Other design file formats can be obtained from your supplier.
MTBMS-5S60W-CF_V0.8.pdf
IP2366 datasheet_cn_v1.13.pdf
IP3264_datasheet_CN_V1.02.pdf
PDF_Makita 5-cell battery pack with 60W USB fast charging, supports same-port charging and discharging.zip
Altium Makita 5-cell battery pack with 60W USB fast charging, supports same-port charging and discharging.zip
PADS_Makita 5-cell battery pack with 60W USB fast charging, supports same-port charging and discharging.zip
BOM_Makita 5-cell battery pack with 60W USB fast charging, supports same-port charging and discharging.xlsx
95811
Southwest Jiaotong University NFC Campus Card
The PCB is drawn based on a map of Southwest Jiaotong University's Xipu campus. It only requires soldering the IC card and two LEDs to function properly. Please remember to update your student ID numbers.
It's not technically sophisticated, but it looks really cool.
Video demonstration link:
[A Campus Card More Suitable for Engineering Students]
NFC_swjtu.zip
PDF_Southwest Jiaotong University NFC Campus Card.zip
Altium_Southwest Jiaotong University NFC Campus Card.zip
PADS_Southwest Jiaotong University NFC Campus Card.zip
BOM_Southwest Jiaotong University NFC Campus Card.xlsx
95813
12V Regulated Power Supply Based on EG1198H
The 12V regulated power supply based on EG1198H supports a maximum power input of 120V.
Calculation formula for output voltage of 12V regulated power supply based on EG1198H :
Actual test results
PDF_12V Regulated Power Supply Based on EG1198H.zip
Altium_12V Regulated Power Supply Based on EG1198H.zip
PADS_12V Regulated Power Supply Based on EG1198H.zip
BOM_12V Regulated Power Supply Based on EG1192H.xlsx
95816
STM32G473CCU6 core board
It was just a core board, that's all.
It's a core board that leads to SWD, IIC, and USART1.
PDF_STM32G473CCU6 core board.zip
Altium_STM32G473CCU6 core board.zip
PADS_STM32G473CCU6 core board.zip
95817
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 18:10:55
