This is the first development board design that aligns with the research and development of integrated circuits. It would be a shame to waste so many Air001 chips I have on hand. This is the smallest MINI single-sided, double-layer development board with automatic download, designed for modular embedding. It's used to research a module within a motorcycle infotainment system and has already been verified. Here's a simple demo video showing the WS2812 lighting up.
IMG_4157.MOV
PDF_Hezhou Air001 Single-sided Double-layer Mini Board.zip
Altium_合宙Air001 Single-sided Double-layer Mini Board.zip
PADS_HezhouAir001 Single-sided Double-layer Mini Board.zip
BOM_HezhouAir001 Single-sided Double-layer Mini Board.xlsx
96026
MP2225GJ-Z Power Management Module
This module, based on the MP2225GJ-Z chip, converts 3.3V and 5V outputs. It uses two MP2225GJ-Z chips, supports a maximum current output of 5A (datasheet), and has an 18V input. The module design is small and compact.
There will be a 0.3V voltage drop when using a 5V input, resulting in 3.0V and 4.7V outputs.
Note: When using a Type-C input, do not use a 12V (DC plug or terminal) input, as the inputs share the same circuit.
Power.mp4
PDF_MP2225GJ-Z Power Management Module.zip
Altium_MP2225GJ-Z Power Management Module.zip
PADS_MP2225GJ-Z Power Management Module.zip
BOM_MP2225GJ-Z Power Management Module.xlsx
96029
TinyVision V851se Heterogeneous AI Vision Network Development Kit
A heterogeneous AI vision network development kit based on V851se, with a 0.5TOPS NPU.
Heterogeneous AI Vision Network Development Kit based on V851se, 0.5TOPs NPU, supports RTSP
TinyVision. Purchase link:
https://item.taobao.com/item.htm?&id=756255119524
Accessory purchase links:
GC2053 Camera: https://item.taobao.com/item.htm?&id=736796459015
RJ45 100Mbps Cable (4P to RJ45 50CM): https://item.taobao.com/item.htm?&id=626832235333
PDF_TinyVision V851se Heterogeneous AI Vision Network Development Kit.zip
Altium_TinyVision V851se Heterogeneous AI Vision Network Development Kit.zip
PADS_TinyVision V851se Heterogeneous AI Vision Network Development Kit.zip
BOM_TinyVision V851se Heterogeneous AI Vision Network Development Kit.xlsx
96030
Simp keychain
Design a simp pendant to remind simps to drink more hot water, etc., to improve their efficiency. May every simp have a home.
Project Description:
With social development, technological progress, economic development, and economic expansion, the rapid advancement of modern electronic, communication, and computer technologies has led to an increase in the phenomenon of "sycophants" (or "sycophants"). This reflects a decline in trust and amplified loneliness in society, a natural human reaction for survival. This project combines embedded technology with the concept of "sycophancy" to design a "sycophant pendant" that reminds users to drink more hot water, etc., to improve the efficiency of sycophancy and provide a home for every sycophant.
Open Source License:
GPL 3.0.
Project Functionality: The project
will remind others to drink more hot water based on different temperatures and humidity levels.
Project Attributes:
This is the first public release of this project, and it is my original work. This project has not won any awards in other competitions.
Project Progress:
2024-01-01: PCB design completed, but not yet tested on a board.
2024-02-01: Soldering and debugging. The hardware
design
aims to be portable. First, it needs a battery, using a TP4056 for charging and a DC-DC chip for voltage regulation to power the ESP8266. It includes 2-3 buttons for changing cities, as many devices don't support this feature.
The software
uses the ESP8266 as the control core and is written in Python. First, the Python firmware is flashed, then the ESP8266 is developed using Python. It connects to a personal hotspot, retrieves weather information, and reminds users to drink more water based on temperature and humidity levels. The first two photos
show
a 3D view of the PCB and a picture of the PCB soldering. The third photo shows the device connected to the personal hotspot after flashing the first firmware. The fourth and fifth photos show the screen displaying weather, wind direction, and reminders to drink water after flashing the second firmware and connecting to Wi-Fi. Pressing the two bottom buttons changes the city; the number of cities increases or decreases, and the information is updated when the first page is refreshed. Pressing the first button resets the settings.
Design Considerations:
First, you need to flash the Python firmware onto the ESP8266. Then, use uPyCraft.exe to open the two files and flash one of the firmware files first. Set your personal hotspot or other Wi-Fi network to the username "WIFI123" and password "12345678". The device will then connect to your Wi-Fi. Next, flash the second firmware. After a short while, the screen will refresh.
Other
C111F83CB7CB16997F109CA29C22A9C6.mp4
Part 1.stl
1537.stl
esp8266-20220117-v1.18.bin
tiangouoledxianshuazhege.py
tiangouoled.py
PDF_Simp Accessory.zip
Altium_licker accessory.zip
PADS_Simp Keychain.zip
BOM_Simp Accessory.xlsx
96031
electronic
