C2NPdE8oF5
Hardware keylogger USBKeylogger_USBHub version
Hardware keylogger.
Installed between a USB port and a keyboard, it records keyboard input
via hardware, making it undetectable by antivirus software.
It adapts to various installation scenarios
and includes Wi-Fi for remote control. It has
3MB of built-in storage
. This version is disguised as a USB Hub. A smaller
firmware version with source code and detailed documentation is available on GitHub: https://github.com/Push3AX/USBKeylogger/
PDF_Hardware Keylogger USBKeylogger_USBHub Version.zip
Altium Hardware Keylogger USBKeylogger USBHub Version.zip
PADS Hardware Keylogger USBKeylogger USBHub Version.zip
BOM_Hardware Keylogger USBKeylogger_USBHub Version.xlsx
96853
Design of a line-following car and a remote-controlled car based on the Liangshan School
Design and implement a small car capable of automatic line following using a Liangshan-style microcontroller. It can also be used as a remote-controlled car.
I. Project Background and Significance:
With the development of technology, intelligent vehicles have been widely used in various fields, such as industrial automation, home services, and healthcare. Among them, the line-following vehicle, as a type of intelligent vehicle, can travel along a preset trajectory and has high practical value. This project aims to design and implement an automatically line-following vehicle using a Liangshanpai microcontroller to promote the popularization and application of intelligent vehicles.
II. Project Objectives:
Design and implement an automatically line-following vehicle with high stability and reliability. The vehicle should be able to travel automatically according to a preset trajectory and adapt to different terrains and environments. The vehicle should possess certain intelligence, such as automatic obstacle avoidance and automatic speed adjustment. Mobile remote control function: Users can remotely control the vehicle's movement via a mobile app, including starting, stopping, speed adjustment, and trajectory setting.
III. Technical Approach:
The Liangshanpai microcontroller is used as the control core of the vehicle, responsible for processing signals from various sensors and controlling the vehicle's movement.
The Liangshanpai microcontroller features high performance, low power consumption, and low cost, making it very suitable for controlling intelligent vehicles. Infrared sensors are used as tracking sensors to detect the trajectory in front of the car.
Infrared sensors have advantages such as high sensitivity and fast response speed, enabling accurate detection of the trajectory. A PID algorithm is used to implement tracking control of the car, allowing it to stably travel along the preset trajectory.
The PID algorithm is a classic control algorithm that can effectively adjust system deviations to achieve a stable state.
Remote control function: Remote communication between a mobile app and the car is achieved via Bluetooth or WiFi.
Users can remotely control the car's movement through the app, including starting, stopping, speed adjustment, and trajectory setting.
IV. Project Implementation Steps:
Hardware Design: Design and manufacture the car's hardware components, including motor drive circuits, sensor interface circuits, and wireless communication modules. During hardware design, factors such as stability, reliability, and power consumption must be fully considered.
Software Design: Write the car's control program, including tracking algorithms, obstacle avoidance algorithms, automatic speed adjustment algorithms, and mobile remote control functionality. During software design, factors such as program efficiency, stability, and readability must be fully considered.
System Integration: Integrate the hardware and software together and conduct system testing. During system integration, it is essential to ensure compatibility, stability, and reliability among the various components.
System optimization: Based on test results, the system will be optimized to improve the car's performance. During system optimization, the actual application environment and user needs of the car must be fully considered.
V. Expected Outcomes:
A car capable of automatic line following will be completed, possessing stability, reliability, and intelligence. This car will be able to travel stably on a preset track and adapt to different terrains and environments. Furthermore, the car will possess certain intelligent features, such as automatic obstacle avoidance and automatic speed adjustment. The mobile phone remote control function allows users to control the car more conveniently, enhancing its practicality and fun. The successful development of this car will provide new ideas and solutions for the popularization and application of intelligent cars.
VI. Circuit Design and PCB Design: The
infrared tracking module is a crucial part of the line-following car. It is responsible for detecting black lines on the ground and sending the detected signals to the microcontroller for processing. Below is a simple analysis of the infrared tracking module circuit.
Infrared Emitter and Receiver: The infrared emitter and receiver are the core components of the infrared tracking module. The transmitting tube emits infrared light, and the receiving tube receives the reflected infrared light. When the transmitting and receiving tubes are aligned with the black line on the ground, the receiving tube receives the reflected infrared light, generating a high-level signal.
Amplification circuit: Because the signal generated by the infrared receiving tube is relatively weak, it needs to be amplified by an amplification circuit before it can be recognized by a microcontroller or other devices.
Filtering circuit: The amplified signal may contain some noise; the filtering circuit can remove this noise and improve the signal purity.
Schmitt trigger: A Schmitt trigger is a shaping circuit that converts the input signal into a rectangular wave, facilitating digital processing by a microcontroller or other devices.
Logic circuit: The logic circuit can determine whether the car is on the black line based on the signal output by the Schmitt trigger. When the car is on the black line, the logic circuit outputs a high level; otherwise, it outputs a low level.
Power supply circuit: The infrared tracking module requires a DC power supply. The power supply circuit converts the battery voltage to a voltage suitable for the operation of the infrared transmitting and receiving tubes.
Through the above circuitry, the infrared tracking module can detect the black line on the ground and send the detected signal to the microcontroller for processing. The microcontroller can control the car's direction of travel based on the received signals, achieving a line-following function.
The Bluetooth module used is the HC-04D dual-mode SPP2.1 + BLE4.0 wireless serial communication module with a baseboard and solder pads; it can be easily found on Taobao.
It supports both SPP2.1 and BLE4.0 protocols. It integrates Bluetooth RF, baseband, protocol stack, and application layer, enabling wireless serial communication.
SPP2.1 is the Bluetooth serial protocol, allowing data transmission between Bluetooth devices via serial port. This protocol is simple, reliable, and widely used for communication between various Bluetooth devices.
BLE4.0 is the low-power version of Bluetooth 4.0, featuring lower power consumption, longer transmission distance, and faster transmission speed. BLE4.0 is ideal for applications requiring long standby times and low power consumption, such as smart homes and wearable devices.
The HC-04D Bluetooth module can communicate with microcontrollers, microcontrollers, and other devices via serial port to achieve wireless data transmission. Its applications are very wide-ranging, including smart homes, industrial control, medical equipment, and smart wearable devices.
In summary, the HC-04D Bluetooth module is a powerful and widely applicable wireless communication module. It can be used for both classic Bluetooth data transmission and Bluetooth Low Energy applications, providing developers with more options.
More importantly, it is inexpensive, making it suitable for this application.
In the use of edge-mounted LED lights, a resistor is usually connected in series. The main functions of this resistor are as follows:
Current limiting protection: LEDs are semiconductor devices, and the magnitude of their operating current greatly affects their lifespan and operational stability. If the operating current is too high, the LED may overheat, leading to a shortened lifespan or even burnout. Connecting a resistor in series limits the LED's operating current, ensuring normal operation.
Brightness adjustment: The brightness of the LED can be adjusted by changing the resistance value of the series resistor. In practical applications, the resistance value can be adjusted as needed to achieve the desired brightness effect.
Flicker prevention: In some cases, LEDs may flicker due to power supply voltage fluctuations or other reasons. Connecting a resistor in series stabilizes the LED's operating voltage, reducing flickering.
Voltage matching: There may be a difference between the LED's voltage and the power supply voltage. Connecting a resistor in series helps match the voltage, ensuring the LED's normal operation.
When choosing a resistor value, the rated current and voltage of the LED light are usually considered. Generally, 10kΩ or 100Ω resistors are common choices because they provide sufficient current limiting without significantly affecting the brightness of the LED light. Of course, the specific resistor value needs to be selected based on the actual situation.
The battery uses two 18650 batteries, providing a combined 7.4V. A charger is also included with the purchase, making it a great value.
PCB_PCB1_2023-10-28.pdf
BOM_Board1_Schematic1_2023-10-28.xlsx
7e49b26058513f193cbacd5d6ad0cbab.mp4
SCH_Schematic1_2023-10-28.pdf
7888d3589e18347d748f2e91ab0366bb.mp4
Liangshan School Remote Control Car Project.zip
PDF_Design of Line-Following and Remote-Controlled Cars Based on the Liangshan School.zip
Altium: Design of Line-Following and Remote-Controlled Cars Based on the Liangshan School.zip
PADS_Design of Line-Following and Remote-Controlled Cars Based on the Liangshan School.zip
BOM_Design of a Line-Following Car and a Remote-Controlled Car Based on the Liangshan School.xlsx
96856
STM32F407
The STM32F407ZET6 core board has Narcida on the front and Keqing on the back. It functions normally in testing and can be customized into a development board by adding peripherals.
Attention! I accidentally used 2.0mm pin headers when drawing the I/O pinouts; you can see it in the diagram. It's very inconvenient. You can replace the 2.0mm pin headers with 2.5mm pitch ones.
PDF_stm32f407.zip
Altium_stm32f407.zip
PADS_stm32f407.zip
96857
LCR bridge tweezers
You can use tweezers to solder a 3.5mm plug to DIY an LCR digital bridge.
PDF_LCR Bridge Tweezers.zip
Altium_LCR Bridge Tweezers.zip
PADS_LCR Bridge Tweezers.zip
BOM_LCR Bridge Tweezers.xlsx
96859
IP5306 charging pad + LED strip
 This IP5306 charging board, featuring 5050 LED beads and a
2020 aluminum profile lighting strip,
can also be used as an under-cabinet light
. The LED strings can be removed to use it as a battery charging board.
The LED driver is an OC5219 constant current driver
. The OC5219 is a continuous inductor current conduction mode step-down LED constant current driver used to drive one or more LED strings. The OC5219 operates from 5.5V to 30V, providing adjustable output current, with a maximum output current of 1A. Depending on the input voltage and external components, the OC5219 can drive LEDs with power supplies up to tens of watts.
Modifying the RCS resistor (R6 in engineering) controls the LED current.
The maximum current is 1A, allowing for multiple LED beads to be connected in parallel.
However, this requires manual cutting and polishing, which is time-consuming.
949f54c50648ad464f7d761e1e96e858.mp4
PDF_IP5306 charging pad + LED strip.zip
Altium IP5306 charging pad + LED strip.zip
PADS_IP5306 charging pad + LED strip.zip
BOM_IP5306 charging pad + LED strip.xlsx
96861
0.87-inch OLED screen substrate
0.87-inch OLED screen substrate, used to verify the screen circuit scheme.
and compatible screen: Zhongjingyuan 0.87-inch OLED screen
supplier number: ZJY087-2832TSWZG02
Bus interface: I2C
This project is used for the verification of the screen driver circuit scheme and as a backup for future projects (^-^).
The screen test firmware and PCB board are both on Github:
https://github.com/MengBowen-328p/0.81OLED_DevBoard
This project is designed using KICAD. If you need to use it, please download the contents of the attachment!
(The editor is full of iced tea dripping water.
The final picture is the actual product.)
0.81OLED_DevBoard.zip
PDF_0.87-inch OLED screen substrate.zip
Altium_0.87-inch OLED screen substrate.zip
PADS_0.87-inch OLED screen substrate.zip
BOM_0.87-inch OLED screen substrate.xlsx
96862
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 19:36:25
