JFET
ESP32-SOLO VGA game console development board
Simple explanation
Have you ever thought about designing a game console yourself? The purpose of this thing is to develop VGA output. At present, VGA display has been successfully implemented, and other content is up to you.
It provides four types of components, buzzer, direction keys and AB, as well as a VGA output interface. There is also an OLED interface, which can be installed depending on the situation.
It adopts extremely advanced Type-C, onboard CH340C, and is directly controlled by the serial port.
You can use ESP32-Wroom and ESP32-Solo. In fact, the difference between the two is not really that big. Of course, scheduling will be easier if there are multiple cores.
How to use and develop
How to use this module? It's actually very simple, just plug in the electricity
The display effect is as follows, it looks pretty good, right?
Of course, for simple use, you need Arduino IDE and post some commonly used add-on board addresses.
http://dan.drown.org/stm32duino/package_STM32duino_index.json
https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json
https://dl.espressif.com/dl/package_esp32_index. json
https://mcudude.github.io/MicroCore/package_MCUdude_MicroCore_index.json
https://mcudude.github.io/MiniCore/package_MCUdude_MiniCore_index.json
The library I use to drive VGA is bitluni's ESP32Lib. Its compilation speed is fast and it is more refined than FABGL.
Pin definitions for all components
VRED 2
VGREEN 15
VBLUE 19
VHSYNC 17
VVSYNC 4
UP 26
DOWN 32
LEFT 14
RIGHT 14
A 33
B 25
START 34
SELECT 35
BUZZER 5
test code
Run the VGA just now to display HelloWorld
#include <ESP32Lib.h>
#include <Ressources/Font6x8.h>
//pin configuration
const int redPin = 2;
const int greenPin = 15;
const int bluePin = 19;
const int hsyncPin = 17;
const int vsyncPin = 4;
//VGA Device
VGA3Bit vga;
void setup()
    //initializing vga at the specified pins
    vga.init(vga.MODE320x240, redPin, greenPin, bluePin, hsyncPin, vsyncPin);
    //selecting the font
    vga.setFont(Font6x8);
    //displaying the text
    vga .println("Hello World!");
  Serial.println("System Online");
void loop()
  delay(10);
You can learn and develop more by yourself
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 00:53:20
  • Do you know the clock system of MSP430F149?
  • sd card file system problem
  • Resigned, scattered
  • Customize the OS platform of wince
  • A 51 timer initial value calculation tool
  • Watchdog
