WKWfq5g
STM32H750-based oscilloscope
1. Analog input signal channels
INA, INB;
2. Power supply module
; 3. Analog signal output channels;
4. Physical display.
BOM_Board1_1_PCB4_2023-11-14.xlsx
Oscilloscope 5th Edition.zip
PDF_Oscilloscope based on STM32H750.zip
Altium_STM32H750-based Oscilloscope.zip
PADS_STM32H750-based Oscilloscope.zip
BOM_Oscilloscope based on STM32H750.xlsx
96992
Radio frequency infrared conversion (Xiao Ai speaker Play installation version)
Infrared RF converter board suitable for installation on Xiaoai Speaker Play, based on 8266
This is a modified version of https://oshwhub.com/wnet/hong-wai-ye-pin-hu-zhuai-mu-kuai, designed for Xiao Ai Play.
The RF receiver module uses the smaller Far-R1L instead of the standard Hummingbird wireless Far-R1. The transmitter module uses the Far-T2L for slightly stronger signal.
Since I only have 433 devices on hand, I only soldered the 433 module; the 315 module was left unused
. I used the program from the referenced link and flashed it, but it doesn't work for some reason. I'm currently investigating the cause.
Problem solved on November 25, 2023: The infrared transmitter's current-limiting resistor R3 was changed to 0 ohms. If you don't have a 0-ohm resistor, just short it.
Also, due to the rcswitch library, many RF remote controls cannot be decoded, such as my Dooya remote. I read this post https://bbs.hassbian.com/thread-14331-1-2.html and understand the reason, but I don't know how to program it. How can I add my own remote control code? I would appreciate any help from experts passing by.
PDF_RF Infrared Conversion (Xiao Ai Speaker Play Installation Version).zip
Altium_RF Infrared Converter (Xiao Ai Speaker Play Installation Version).zip
PADS_RF Infrared Conversion (Xiao Ai Speaker Play Installation Version).zip
BOM_RF Infrared Conversion (Xiaoai Speaker Play Installation Version).xlsx
96994
TP4056 Lithium Battery Charging Management
This design is for a lithium battery charging board based on the TP4056, and the principle is based on the official recommended circuit of TP4056.
The TP4056 is a charging management chip. This time, it was used to charge a 1500mAh 18650 battery. The designed charging current was 100mA. The actual charging speed was slow and there was basically no heat generation. For personal DIY, the corresponding resistor can be changed to increase the charging current.
This design is a small attempt based on actual needs. Please forgive any shortcomings.
(1) When the battery is not connected, the green light is always on and the red light is flashing.
(2) When the battery is connected, charging begins and the red light is always on
. (3) When the battery is fully charged, the red light goes out and the green light stays on.
PDF_TP4056 Lithium Battery Charging Management.zip
Altium_TP4056 Lithium Battery Charging Management.zip
PADS_TP4056 Lithium Battery Charging Management.zip
BOM_TP4056 Lithium Battery Charging Management.xlsx
96996
STM32 minimum system board, small size integrated switching power supply
This minimum system board uses the TPS54308 switching power supply chip to implement a small-size switching power supply. The 662kJ is used as a LOD (suitable for 2s lithium batteries). It is smaller than a Raspberry Pi or Pico and integrates a switching power supply.
This minimum system board uses the TPS54308 switching power supply chip to achieve a small-size switching power supply without diodes. While small, its performance is relatively poor. The system board is only 42mm long and 20mm wide, theoretically achieving a maximum input of 24V and an output of 2A (actually, the maximum measured input is 10V; increasing the voltage causes a decrease in power supply efficiency and heat generation, which is inconsistent with the datasheet, possibly indicating a problem with my board). The power chip requires 8V to start the switching power supply. After starting, it will shut down the output when the voltage drops below 7.2V. Theoretically, the switching current at this point is 2µA, essentially negligible. This suggests that using a 2s lithium battery would effectively protect the battery from over-discharge. To further reduce size, a 662k linear regulator is used to power the 32-bit microcontroller. Due to size limitations, the load power cannot be too high. Reverse connection protection and soft-start circuitry are not included; these can be designed separately if needed. I will also optimize this circuit board when I have free time. This board is for learning purposes. Note that its 5V output capability is relatively poor; do not connect it to high-power devices. The recommended operating current is below 0.5A, with an instantaneous current of around 0.8A being preferable. The power input is located at the top left corner of the board. Due to size constraints, I used 2.54mm pitch headers, and no power inductor was used. This may result in some instability. Note that this board was designed during my first year of university, and I have since optimized it. Therefore, many parts of the schematic do not correspond to the PCB. The BOM (Bill of Materials) is not suitable for this PCB. Due to space limitations, the power supply values ​​are not marked on the PCB. When soldering, you can select the appropriate resistors and capacitors based on the values ​​in the schematic.
Comparison of the board and pico:
Board images (my board is a first version; the input capacitors use advanced millimeter-level 3D stacking technology because I didn't have the same model available):
Ripple test (I didn't use the correct ripple testing method, and only later discovered that the probe used 10x attenuation, which I didn't notice during testing; I was wondering why the ripple was so good. I used alligator clips for ground return, so this only gives a rough estimate):
8V 0.2A switching power supply output ripple approximately 140mV
; 8V 0.5A switching power supply output ripple approximately
148mV; 8V 0.2A switching power supply output ripple approximately
176mV; 8V 0.2A LDO output ripple approximately 256mV; 7.4V
no-load current;
9.4V no-load current;
8V 0.2A load (efficiency approximately 72.3%);
8V 0.5A load (efficiency approximately 69%).
8V 0.8A load (efficiency approximately 64.6%):
The following are the board tests (all images were tested under natural heat dissipation conditions at room temperature of 24 degrees Celsius):
First, the board's heat generation was tested. The following is a thermal image of the
board after 10 minutes of no-load operation, with a temperature of approximately 32 degrees Celsius. After 5 minutes of 0.2A load operation, the temperature was approximately 42 degrees Celsius.
After 5 minutes of 0.4A load operation, the temperature was approximately 63 degrees Celsius.
gpiotext.zip
PDF_stm32 Minimum System Board Small Size Integrated Switching Power Supply.zip
Altium_stm32 minimum system board, small-size integrated switching power supply.zip
PADS_stm32 Minimum System Board: Small-Size Integrated Switching Power Supply.zip
BOM_stm32 Minimum System Board Small Size Integrated Switching Power Supply.xlsx
96997
STM32F103C8T6 Industrial Control Expansion Board
A minimum system board with STM36F103C8T6
power supply,
10 inputs, and 10 outputs is required. Other pins should be connected via headers.
The maximum input signal voltage is 24V,
and the output is 3.3V.
power supply,
WeChat_20231125132002.mp4
WeChat_20231125131955.mp4
PDF_STM32F103C8T6 Industrial Control Expansion Board.zip
Altium_STM32F103C8T6 Industrial Control Expansion Board.zip
PADS_STM32F103C8T6 Industrial Control Expansion Board.zip
BOM_STM32F103C8T6 Industrial Control Expansion Board.xlsx
96998
Hezhou Air001 Minimum Development Board
air001 Minimum Development Board
PS: I've also reserved soldering pins for the DHT11 temperature and humidity sensor on the development board for easy data acquisition and verification later.
The Hezhou Air001 is a TSSOP20 packaged MCU, employing a high-performance 32-bit ARM® Cortex®-M0+ core, with 32Kbytes of Flash and 4Kbytes of RAM. The chip integrates multiple USART, IIC, SPI, and other communication peripherals, five 16-bit timers, one 12-bit ADC, and two comparators. For detailed information, please refer to the datasheet: AIR001 Chip Datasheet.pdf and the Air001 Register Manual. For serial
port downloading, connect the serial module's RX pin to the Air001's TXD (PA2), connect the serial module's TX pin to the Air001's RXD (PA3), and connect the chip's or development board's GND to the serial module's GND.
Before each download, you need to manually enter the bootloader:
First, press and hold the BOOT button (i.e., pull the BOOT0 pin high)
, then press the RST button and release
the BOOT button
. After the download is complete, you may need to manually press the RST button to reset and
resume normal operation. Note
: This development board does not have an automatic download circuit; you need to manually enter the bootloader to download.
For SWD debugging/downloading
, the wiring is as follows: connect the debugger's SWDIO to Air001's SWDIO (PA13), connect the debugger's SWCLK to Air001's SWCLK (PA14), and connect the chip's or development board's GND to the debugger's GND.
PDF_HeZhouAir001 Minimum Development Board.zip
Altium_合宙air001 Minimum Development Board.zip
PADS_合宙air001 Minimum Development Board.zip
BOM_合宙air001 Minimum Development Board.xlsx
96999
Greenhouse temperature detection device
This paper designs and implements an ambient temperature detector based on the STC32 microcontroller, which can accurately detect the ambient temperature, display the temperature value, draw a line graph, and record the time.
The overall system design of this project uses an STC32 microcontroller as the core controller. A DS18B20 temperature sensor detects the ambient temperature, transmits the data to the microcontroller for processing, and then displays the temperature value on a 2.8-inch TFT LCD screen, plotting a line graph of the temperature change over time. A DS1302 microcontroller records the time. For power supply, a Type-C charging interface provides direct power. Considering power outages, a lithium battery is used as a backup power source, charged by a TP4056 charging chip. A P-channel MOSFET is used for power switching, and an RT9193 converts the power to 3.3V to power subsequent circuits. A passive buzzer is also included to alert the user.
1. The main controller uses an STC32 microcontroller as the core controller. Domestic chips are relatively inexpensive, suitable for low-cost applications. They also have a relatively complete Chinese manual, with detailed explanations of virtual serial port and SPI communication used in this project, making development easy and suitable for beginners.
2. The DS18B20 temperature sensor is used for temperature acquisition. The DS18B20 is a single-bus digital temperature sensor with advantages such as small size, low power consumption, and high accuracy. Its working principle is to detect temperature changes by measuring the resistance change of a thermistor, and then convert the temperature value into a digital signal output. In this project, we connect the DS18B20 to the I/O port of an STC32 microcontroller, which reads and processes the temperature value.
3. Temperature display uses a 2.8-inch TFT LCD screen to display the temperature value and line graph. TFT LCD screens have advantages such as vibrant colors, clear images, and wide viewing angles. Their working principle is to control the rotation angle of liquid crystal molecules through thin-film transistors to achieve image display. In this project, we connect the TFT LCD screen to the SPI interface of the STC32 microcontroller. The microcontroller reads the DS18B20 temperature data, processes and displays it according to the current time, and confirms the coordinates by sequentially marking points on the screen to obtain the line graph.
4. Time is achieved using a DS1302 clock chip. The DS1302 is a trickle-charged clock chip from Dallas Semiconductor. It contains a real-time clock/calendar and 31 bytes of static RAM, and can communicate with a microcontroller via a simple serial interface. It features a simple 3-wire interface, and the real-time clock calculates seconds, minutes, hours, date, month, day, week, year, and leap year compensation valid until 2100. It supports battery-powered general-purpose RAM, operating from 2.0V to 5.5V, using less than 300nA of current at 2.0V. The end-of-month date is automatically adjusted for months with fewer than 31 days, including leap year corrections. The clock runs in 24-hour or 12-hour format, and the AM/PM indicator uses synchronous serial communication, simplifying the interface between the DS1302 and the microprocessor. Alternatively, the internal RTC real-time clock of the STC32 can be used, requiring an external 32.768kHz crystal oscillator.
While a Type-C power supply is used directly, a lithium battery is added as a backup power source to prevent power outages that would disable the entire system and lose time data on the DS1302. A TP4056 charging chip is used for charging, and a P-channel MOSFET is used for power switching. The output voltage is converted to 3.3V by an RT9193 power conversion chip to power the subsequent circuitry.
The RT9193 is an LDO linear regulator with a 300mA output current, ultra-low noise, and fast adjustment. At full power (300mA) output, the voltage drop can be as low as 220mV. Its input voltage range is 2.2V to 5.5V, and its output voltage is 3.3V. It features overcurrent and short-circuit protection. The RT9193 uses an SOT23-5 package.
Circuit Design Summary: In this project, we used advanced components such as a temperature sensor, LCD display, clock chip, and power management chip. Through reasonable circuit design and software programming, we achieved the functionality and coordinated operation of each component. Specifically, we used a DS18B20 temperature sensor to detect the ambient temperature, a 2.8-inch TFT LCD screen to display the temperature values ​​and line graphs, a DS1302 clock chip to record time, and a lithium battery for power supply and a TP4056 charging chip for charging management. Through the coordinated operation of these components, we successfully implemented the functions of detecting, displaying, and recording ambient temperature.
Component Preparation: Before circuit installation, the necessary components must be prepared. The components required for this project include an STC32 microcontroller, a DS18B20 temperature sensor, a 2.8-inch TFT LCD screen, a DS1302 clock chip, a TP4056 charging chip, a P-channel MOSFET, an RT9193 power conversion chip, a lithium battery, and a passive buzzer. When purchasing components, attention should be paid to their model, specifications, and quality to ensure the normal operation of the circuit. All components for this project can be purchased from LCSC Online Store.
Soldering and Connection: After preparing the components, the soldering and connection of the components began. First, the components need to be inserted onto the circuit board according to the circuit diagram, and then soldered using a soldering iron. When soldering, pay attention to the following points:
1. Soldering time should not be too long, generally no more than 3 seconds, to avoid damaging the components or the circuit board.
2. The soldering temperature should be moderate, generally around 350℃. Too high a temperature will damage the components or deform the circuit board, while too low a temperature will result in poor soldering.
3. A "three-step method" can be used for soldering. First, heat the soldering iron to the appropriate temperature, then place the solder wire on the solder joint, and finally use the soldering iron to melt the solder wire and wet the solder joint. Maintain the stability and uniformity of the soldering iron during soldering to avoid problems such as cold solder joints or poor soldering.
4. Pay attention to safety during soldering to avoid dangers such as electric shock or burns. Also, keep the soldering environment clean and tidy to avoid dust or debris affecting the soldering quality.
Debugging Preparation: After the circuit is installed, circuit debugging is required to ensure the circuit works properly. Before debugging the circuit, the following preparations need to be made:
Check whether the connections between the components on the circuit board are correct and reliable, and whether there are any problems such as cold solder joints or short circuits. Check whether the power supply is normal, and whether there are any problems such as excessively high or low voltage. Prepare the necessary testing tools, such as multimeters and oscilloscopes, for measurement and observation during debugging. Write test programs according to the functional requirements of the circuit to verify functionality and perform performance testing during debugging.
Debugging techniques: Start debugging with simple functions and gradually transition to complex functions. This allows for step-by-step troubleshooting and avoids solving multiple problems at once. Divide the circuit into different modules and debug them separately. This makes it easier to find the problem and avoids troubleshooting the entire circuit. Keep records during debugging. Record the problems encountered and their solutions for future reference.
Debugging techniques: Through reasonable circuit design and software programming, we successfully implemented the functions of detecting, displaying, and recording ambient temperature. During circuit debugging, we adopted techniques such as modular debugging and the use of simulation software to improve debugging efficiency. Through debugging, we verified the various functions and performance indicators of the circuit, and also discovered and resolved some problems. Ultimately, we successfully completed the design and implementation of the ambient temperature detector.
Project Outcomes:
The implementation steps of this project included the following stages: system design, hardware construction, software programming, system testing, and system optimization. During the project implementation, we adopted advanced components and technologies, and through reasonable circuit design and software programming, we realized the functions and collaborative operation of each component. Ultimately, we successfully completed the design and implementation of the ambient temperature detector, achieving the expected goals and requirements.
The project outcomes include the following aspects:
1. Designed and implemented an ambient temperature detector capable of accurately detecting the surrounding ambient temperature, displaying the temperature value, plotting a line graph, and recording time.
2. Mastered the selection and usage methods of components such as temperature sensors, LCD displays, clock chips, and power management chips.
3. Mastered C language programming and microcontroller development technologies, realizing the functions and collaborative operation of each component.
4. This project fostered teamwork and problem-solving skills, and improved practical abilities and innovation.
Summary and Reflection: During the design and implementation of this project, we encountered some difficulties and problems, but through teamwork and cooperation, we successfully solved them. During the project's implementation, we also learned a great deal of knowledge and skills, improving our practical abilities and innovation. At the same time, we also realized some shortcomings, such as the need for further improvement and refinement in circuit design and software programming.
Through this project, we deeply understood the importance of teamwork and problem-solving skills. In future studies and work, we will continue to strive to improve our abilities and work hard to better complete projects and realize our dreams.
Final Product Showcase:
Code is attached.
STC32_1.rar
PDF_Greenhouse Temperature Monitoring Device.zip
Altium_Greenhouse Temperature Monitoring Device.zip
PADS_Greenhouse Temperature Monitoring Device.zip
BOM_Greenhouse Temperature Monitoring Device.xlsx
97000
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-26 02:07:45
