13710 views|11 replies
Posts
Resources
The OP
About ucosii task switching problem [Copy link]
I called taskCreate() in main() to create two tasks, the code is as follows static void taskCreate (void){ // DispSem = OSSemCreate(1); OSTaskCreate (taskA, (void *)0, &Task_AStk[TASK_A_STK_SIZE-1], 1); OSTaskCreate (taskB, (void *)0, &Task_BStk[TASK_B_STK_SIZE-1], 2); } static void taskA(void *parg){ init_LCD(); InitUART0(); InitUART1(); ScanKeyInit(); MainTask(); } static void taskB(void *parg){ UARTPrintStr("hello OK"); Mcard_Init(); while(1) { Cika_task(); } } taskB In the code, the card is swiped and the GUI is displayed in taskA. There is no system delay or waiting event in taskA. Originally, this code was burned into the board for experimentation, but the card number data can be displayed when the card is swiped. According to my understanding, the system runs taskB first, waits for the system clock to schedule the task, switches the task, and runs taskA. Because taskA has a high priority, the system clock task scheduling will not switch taskB. Even if the card is swiped by interrupt processing, the track information processing is done in taskB, so the card number data should not be displayed. Please explain the principle. Thank you
Latest reply
This question is quite interesting. Generally speaking, once the system is executing the idle task TaskIdle, it means that other tasks have been suspended or deleted (because the idle task has the lowest priority) and are waiting for delays, semaphores, messages, etc. In addition, we also see that the actual processing in the code of the idle task TaskIdle is a simple continuous self-increment processing of a 32-bit variable (OSIdleCtr++), and there is no task scheduling switching function OS_Sched(), mainly considering the CPU burden, and there is no need for it. So if you want to switch out of the idle task, you can only do it through the interrupt level. This interrupt can be a clock beat interrupt (delay timeout processing), or an external asynchronous trigger event interrupt processing (I/O, exception fault processing), etc., rather than actively switching tasks at the task level (such as xxxPost, etc.), because all other tasks are suspended at this time. Here is a very interesting question. If all user application tasks (except idle tasks) are not suspended because of their own calls to the Dly delay function, they may be suspended because of waiting for events, semaphores, messages, etc., then there may be a problem, which is often called "deadlock". At this time, you can only wait for timeout processing. Therefore, when designing the system, you should pay attention to prevent this situation as much as possible. On the contrary, if it is not because of the above situation to enter the idle task TaskIdle, there is no big problem. After the delay is over, when the clock beat interrupt exits, OSIntExit() will be called to determine the task scheduling switch, so as to make a decision on whether to perform task switching.  Details Published on 2011-4-8 14:01
2125
Posts
Resources
The first problem is: ucos reserves the highest 4 priorities (0, 1, 2, 3) and the lowest priority OS_LOWEST_PRIO-1 for statistical tasks. The second problem is that the above code alone cannot explain your problem.
Personal signature处处留心皆学问!
Posts
Resources
Thank you very much for your answer.
First: The top four priorities are reserved, but they can be used. The statistics task is the second lowest priority, the lowest priority is the idle task that does nothing in an infinite loop, and the statistics task can be unloaded. Second: Maybe my writing ability is not good enough. In fact, the functions called in tasks A and B are all drivers and other modules, which should have nothing to do with the ucosii task. [ This post was last edited by ziffyppo on 2011-3-2 09:37 ]
Posts
Resources
Actually, I have not figured out how the tasks are switched
. Let's ignore the contents of tasks A and B for now.
Can anyone tell me how the tasks are done? Thank you very much
2125
Posts
Resources
2125
Posts
Resources
If the content in the task is ignored: Then task A task B When system tasks A and B are established, task A has a higher priority, so execute A. When there are (semaphores, event markers, message queues, etc. and OSTimeDly), execute the lower-level task B. When (semaphores, event markers, message queues, etc. and OSTimeDly, interrupts), if task A enters the ready queue at this time, A will be executed, otherwise the idle task will be executed.
Posts
Resources
Thank you very much
for your answer!
I got the answer I wanted.
I just found a ucos simulator to remove the content in the task and only print the debugging information, which also confirmed the conclusion. I
understand the mechanism, but I am more confused, because the ucos framework I use now is ready-made, I just make adaptive changes, and the task does not have the conditions for switching tasks at all. The gui uses ucgui, so I can only continue to study the source code.
Thanks again!!! :)
298
Posts
3685
Resources
Daicheng is such a warm-hearted person!
Posts
Resources
Originally posted by daicheng on 2011-3-2 10:08 If the content in the task is ignored: then task A task B When system tasks A and B are established, task A has a higher priority, so execute A when there are (semaphores, event markers, message queues, etc. and OSTimeDly) execute the lower-level task B, when (semaphores, event markers, message queues, etc. and OSTimeDly ...
May I ask: How does a task switch from an idle task to execute another task?
459
Posts
Resources
I have already answered this question in the UCOS FAQ. Please refer to it for reference!
44
Posts
Resources
When a clock interrupt occurs, the system scans the task ready table and switches if there is a ready task.
Posts
Resources
Originally posted by CCTV-10 on 2011-3-21 23:11 May I ask: How does a task switch out of the idle task to execute another task?
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
