Touch switch circuit made with 5G673
Source: InternetPublisher:国民男神经 Keywords: Switching Circuit Updated: 2024/09/29
The touch switch circuit made of 5G673 is shown in the figure. The circuit is composed of 5G673 IC, relay and some resistors and capacitors. 5G673 is an 8-speed interlocked output PMOS integrated circuit. M1~M6 are six metal touch pieces. Their input is connected to the positive voltage through resistors R1-R6, so they are usually in a high potential state, and the output ends are all low potential. When any one of the metal pieces M1~M6 is touched by hand, the corresponding output end becomes a high level, and a voltage drop is generated on resistors R7~R12 to turn on the transistor of this circuit, thereby driving the light-emitting diode for indication and the relay to attract to achieve the control purpose. If you press the M1 touch piece, the transistor V1 is turned on, and the relay K1 is attracted to control the circuit to work.
Relays K1~K6 use 12V 4099. If there are no special requirements, just follow the circuit diagram.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- How to build a simple tachometer using an infrared reflectance sensor
- Tutorial for building a remote-controlled Arduino Air-Boat
- What is a RADAX motor?
- DC motor drive circuit composed of L293D
- Working principle of one Xipu STR soft starter controlling two motors
- Motor self-starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of a four-bit remote control component capable of remote reset
- Smoking Cessation Circuit
- High performance infrared remote control switch circuitb
- Ventilation fan infrared remote control switch circuit
- Induction automatic switch circuit
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Gas-sensitive alarm circuit 2
- Temperature switch circuit three
- Temperature switch circuit 2
- Half-wave synchronous detection circuit composed of switching circuit
- Ultrasonic remote control light switch circuit
