Home >
Microcontroller >Interface Circuits > USB-serial port conversion circuit made with CP2102 chip
Source: InternetPublisher:走马观花 Keywords: CP2102 USB serial port conversion Updated: 2023/01/10
USB -serial port conversion circuit made with CP2102 chip
CP2102 is a USB-to-serial chip developed by SI1bab. It is small in size and can form a simplest USB-UART solution without any peripheral components. The communication rate can reach 1Mbps, which makes it easy to upgrade serial products to USB ports. The simplest application schematic of CP210 can be simplified to form a high-performance USB-UART converter without any peripheral components. The schematic diagram is as follows
Of course, if there is enough space, it is recommended to add some peripheral components, such as decoupling capacitors, power indicators, etc., as shown in the figure below
![USB-serial port conversion circuit made with CP2102 chip](https://www.eeworld.com.cn/circuit/upload/202301/4/b1f95639b2b095c981f9a30eb90ba7d37443ec86.gif)
The interface GND, TXD, RXD, RST, 5V, 3.3V can adapt to different voltage occasions. This chip is very convenient for those who don't have a serial port but need serial port debugging.
![USB-serial port conversion circuit made with CP2102 chip](https://www.eeworld.com.cn/circuit/upload/202301/4/7677b0e9cf081763ccca02d27451afe9aadebf89.gif)
Latest Microcontroller Circuits
- How to use the GPS module of STM32F103C8 to obtain location coordinates
- Homemade bidirectional reversible length measuring device for rubber tubes
- Digital signal isolation interface circuit
- Interface circuit between AD574A and single chip microcomputer
- Using 89C2051 to make a four-way digital display water level controller circuit
- Interface circuit composed of 8051 single chip microcomputer and 74LS165
- How to make a numeric keyboard using XIAO RP2040
- How to design an ESP32-based microcontroller development board
- Experiment on using 51 microcontroller to drive relay
- Use microcontroller to make simple timing controller for electric fan
Popular Circuits
- Provides USB Type-C® port chip solutions for lithium battery-powered devices
- STMicroelectronics USB Type-C port protection IC technology
- Additional power circuit design for USB devices
- Charger circuit powered by USB and adapter
- Based on TNY264P5 Volt/1.5A switching power supply circuit diagram
- USB lithium battery charging circuit and PCB schematic diagram
- USB device additional power
- USB signal generation circuit
- A little summary of the operating principles of single-chip microcomputer
