Charger circuit powered by USB and adapter
Source: InternetPublisher:fish001 Keywords: USB adapter power supply charger circuit Updated: 2021/03/23
Many charger ICs today have power-down control (Figure 7). Integrating this functionality goes beyond simply replacing external components. Because the integrated charger understands the operation of the switching circuit, it helps improve switching when the power supply changes.
Figure 7. Dual-input chargers such as the MAX8844 handle chargers powered by USB and adapters. The device also features input overvoltage protection up to 28V.
A common design consideration with chargers is the issue of powering from multiple sources , especially with circular connectors that may be connected to the incorrect adapter. To avoid such an event, the MAX8844 disables charging from input supplies higher than 7.5V, and can withstand and block inputs up to 28V, effectively protecting the battery, charger, and downstream circuitry from being mistakenly connected to any other type of adapter. . In addition, the MAX8844 features an overvoltage-protected LDO biased from the USB and adapter (IN) inputs that can deliver 30mA to the system. These LDO outputs (SAFE USB and SAFEOUT) remain active whether the charger is enabled or not . Other charging functions performed by the device include battery detection, thermal limiting, reducing charge current at extreme ambient temperatures (to maintain lower die temperatures), auto-starting logic outputs, and notifying the system when external power is applied.
- The basic principles of power supply design. What are the key components of a power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Step-down power supply for driving relays
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Detailed explanation of 5v charger circuit diagram
- Voltage-current converter constructed with XTR110
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- LM317T voltage regulation adjustable circuit diagram explanation
- Tree-trunk main wiring system diagram b
- Mobile phone charger circuit 2
- Wiring a when the leakage protector supplies power to unbalanced loads in the TT system
- Interface circuit between power supply coupler and PLC
- Interface circuit between power supply coupler and triode b
- Incandescent lamp life extension circuit 6
- Short circuit protection circuit for control circuit powered by isolation transformer
- Audio powered noise limiter
- Mains power supply delay automatic extinguishing touch switch
- Circuit for supplying power to frequency counter via RS232
