Stepless speed regulation circuit using auxiliary power supply
Source: InternetPublisher:吃掉星星 Keywords: Stepless speed regulation power supply speed regulation circuit BSP Updated: 2020/06/16
The circuit is shown in Figure 3-171. In the figure, the auxiliary power supply is a single-phase AC power supply , and the output current is supplied to the balancing resistor R through the single-phase half-wave control bridge (
composed of diodes VD7, VD8 and thyristors vl, V2). , the trigger circuit of the thyristor is a full-
wave resistor-capacitor phase-shift bridge.
By adjusting the potentiometer RP, the trigger conduction angle of the thyristor can be changed, so that the motor can
be continuously adjusted within the range of 300 to 900r/min.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to choose the right level of integration to meet motor design requirements?
- Car ice warning circuit sharing
- An automated model railroad layout project using a microcontroller
- Working principle of one Xipu STR soft starter controlling two motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and principle analysis of practical electric curtain remote control device
- Design and production of radio remote control fan stepless speed regulator
- Homemade anti-theft watchdog
- Set timing circuit when power is on
- Electronic thermometer circuit
- Inpatient pager circuit
- Greenhouse temperature control circuit
- Parallel crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- Wireless microphone circuit
- Power phase sequence display circuit
