Control circuit with forward and reverse rotation, reverse braking and hierarchical speed regulation functions
Source: InternetPublisher:三月小雨 Keywords: Control circuit speed regulation current relay BSP Updated: 2020/12/20
The circuit is shown in Figure 3-168. It uses the controller SA to adjust the speed in stages and control the forward and reverse rotations; the reverse braking is controlled by the overcurrent relay KI connected in the rotor
circuit ; the current relays KIi~KI3 are used as the three relays of the motor. Phase overcurrent protection;
zero-voltage relay KA is used for undervoltage protection.
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to Make a Simple Chicken Incubator
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How can we make the robot move precisely on a predefined path?
- An automated model railroad layout project using a microcontroller
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What are the challenges in designing a permanent magnet linear generator?
- Temperature control circuit design and analysis
- Night dog barking anti-theft reminder circuit
- Bicycle anti-theft alarm
- Rural vegetable greenhouse lighting circuit
- Agricultural small tractor lighting circuit
- Straw returning to field crusher circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- ring amplitude modulation circuit
- Wien bridge oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
