Timing circuit that prohibits restarting
Source: InternetPublisher:常思一二 Keywords: Timing circuit relay BSP Updated: 2021/02/23
![Timing circuit that prohibits restarting](http://www.eeworld.com.cn/circuit/upload/680932c156e4649f656b0b00c2c90df0/2f9be25260e9ae3e4553652312413587.jpg)
The above figure shows an underground oxygen concentration detection circuit, which can be used in underground operating environments to detect the oxygen concentration in the air. The oxygen concentration detection sensor in the circuit converts the detection result into a DC voltage. After passing through the circuit amplifier ICl-1 and the voltage comparator ICl-2, it drives the transistor and rri, and then rri drives the relay . After the relay operates , the contact is connected. , the buzzer sounds to remind people that the oxygen concentration is too low, attracting people's attention.
- How to Make a Soft Latch Circuit
- Fabrication of multi-cell lithium battery charging circuit
- Introduction and principle analysis of switching regulated power supply
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Single-power supply circuit for ISO122P/ISO124
- Constant current LED lamp driver circuit with soft start and anti-shock
- Power supply circuit that can reduce LM317 ripple
- Car power 1.5V-12V six-speed converter
- Adjustable voltage regulated power supply circuit
- How to Select Modular EMI Filters for AC-DC Converters
- Motor overcurrent protection circuit
- Bone hyperplasia treatment circuit
- Rice mill circuit
- AC voltmeter
- Wien bridge oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- color discrimination circuit
