Electronic doorbell circuit
Source: InternetPublisher:失踪的猫 Keywords: Electronic doorbell oscillator Updated: 2024/10/28
The figure shows the electronic doorbell circuit, which consists of multivibrators VT1, VT2 and power amplifiers VT3, VT4.
When the push button switch SB is turned on, the multivibrator starts to oscillate. R1 and R4 are the collector load resistors of transistors VT1 and VT2. The resistors R2 and R3 respectively add forward bias to transistors VT1 and VT2. Capacitors c1 and c2 are charged alternately to make the transistors work normally and generate audio oscillation. The parameters of the two transistors should be as consistent as possible. If the parameters are inconsistent, the oscillator will eventually stop working. If this happens, the resistance value of R2z or R3 can be appropriately adjusted to make the multivibrator oscillate. The oscillation signal is amplified by the power amplifier composed of transistors VT3 and VT4 and sent to speaker B, making the speaker sound. Changing the capacity of capacitors c1 and c2 can change the tone.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Analysis of the working principle of car garage door lights
- The meaning and importance of circuit protection, common types of circuit protection
- Tutorial for building a remote-controlled Arduino Air-Boat
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of one Xipu STR soft starter controlling two motors
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of the principle of automatic power-off switch during power outage
- Simple three-phase motor phase loss protection circuit
- Delay switch made with LM431
- Square wave and triangle wave oscillator circuit composed of 5532
- crystal controlled oscillatorb
- Inductive three-point oscillator
- phase shift oscillator
- Triangular wave oscillator using 2 operators
- Self-excited intermittent oscillator practical circuit b
- Three-way flashing light string circuit (5)
- Refrigerator door opening alarm circuit
- Incandescent lamp flash circuit using LM3909 as oscillator
- Adjustable frequency range 10:1 oscillator.gif
