One of the automatic control circuits that only allows the motor to run in one direction
Source: InternetPublisher:王达业 Keywords: Motor BSP power supply Updated: 2020/04/06
90. In some places, the motor is only allowed to run in one designated direction. Even when the power phase sequence
is reversed for some reason (such as incorrect connection after external circuit maintenance), the motor must be guaranteed to run in the designated direction. Otherwise, personal and equipment accidents may occur
. For this purpose, a phase sequence discriminator can be used for control.
The circuit is shown in Figure 3-90. When the phase sequence of the power supply is correct, that is, when the phase sequence is U, V, W, the neon bulb Ne does not light up, the relay
KA is closed, and the start button SBi is pressed, the contactor KMi is closed, and the motor starts running in the forward direction. If the power phase sequence
is wrong, Ne lights up and KA releases. Press the SBi, KMz suction table, change the phase sequence of the motor and then connect it to the power supply . The motor
will still start running in the forward direction.
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- An automated model railroad layout project using a microcontroller
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- An experimental model of an infrared radio alarm
- Magnetic door and window anti-theft alarm
- Delay switch made with LM431
- Motor forward and reverse control wiring diagram (2)
- Electric massager circuit
- Pulse therapy circuit
- Peanut and melon seeds roasting machine circuit
- Straw returning to field crusher circuit
- Farmland drainage automatic control circuit
- DC ammeter
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Sawtooth wave generator circuit (2)
